Post by aklackner » Fri Sep 20, 2019 9:40 pm
And just to finish strong:
AC lines to/from firewall in place
And since I’ve never really liked installs with the cage that comes with a lot of aftermarket radios but want the option to stream from my phone:
Post by aklackner » Mon Sep 23, 2019 7:49 pm
Some more ac lines and power steering starting to go in.
Post by aklackner » Mon Sep 30, 2019 6:36 pm
Wasn’t pleased with replacement options so took the time and effort to clean up the original AC condenser. Power steering cooler also got cleaned up. All got several coats of Eastwood radiator specific paint which should help or at at least not interfere with cooling/heat transfer.
Also got the 4awg power run back to the hatch fusebox to more or less complete the hatch wiring.
Post by Stin1 » Mon Sep 30, 2019 7:29 pm
That's something I wasn't expecting. I have seen the box and don't remember where . That's cool.
Post by aklackner » Mon Sep 30, 2019 8:19 pm
Stin1 wrote:That's something I wasn't expecting. I have seen the box and don't remember where . That's cool.
The fuse box (center) was a generic fuse/relay box from Amazon. The Alpine box (against rear) is a drop-in 8” powered subwoofer.
Post by Dave7CDMTYPER » Mon Sep 30, 2019 11:41 pm
You could consider a little Dynamat around the sub?
Post by aklackner » Mon Sep 30, 2019 11:57 pm
Dave7CDMTYPER wrote:You could consider a little Dynamat around the sub?
Most of the hatch floor was done with 80mil Noico soundmat (similar to dynamat extreme). :)
I was pretty happy with how it came out. Exhausting work but for it to work well it needs to get really formed in.
Post by Dave7CDMTYPER » Tue Oct 01, 2019 2:40 am
aklackner wrote: Mon Sep 30, 2019 11:57 pm
Most of the hatch floor was done with 80mil Noico soundmat (similar time dynamat extreme). :)
Ah now I see that in the pic. You're many steps ahead of us as usual. :trophy:
Post by aklackner » Tue Oct 01, 2019 7:59 am
Dave7CDMTYPER wrote: Tue Oct 01, 2019 2:40 am You're many steps ahead of us as usual. :trophy:
Two years and the engine bay is barely starting to get put together, I wouldn't say I'm ahead of anyone :lol:
Post by aklackner » Tue Oct 01, 2019 8:31 pm
Not a massively productive day but:
Test fit a Koyo crossflow radiator in the LS to confirm coolant hoses would work.
Then test fit it in the ITR
Unfortunately found the OEM coolant reservoir wouldn’t work
Also test fit the front under panel, finally some thing that bolts right on without any modifications.
