Post
by coolhandluke » Fri Nov 01, 2019 10:48 am
NOCSUCOW wrote: ↑Thu Oct 31, 2019 10:25 pm
...I'll still do open track days, time attacks, ....and I guess autocross with it until I can get the OEM one back in.
I wouldn't recommend tracking on Autozone/Napa/other brand axles. If you do, bring spares.
I ran Drive Shaft Shop (DSS) Stage 1 axles in my 98 for about ten years before switching to Raxles "VIR" spec.
Post
by aw614 » Fri Nov 01, 2019 10:53 am
I take the raxles VIR spec have vents on them?
- Site Admin
- Badge Number: 97 #00151
Post
by jayhaire » Fri Nov 01, 2019 11:20 am
Venting and grease material are important.
The RealTime ITRs originally had vents before the grease changed.
- IMG_20190406_174519.jpg (2.82 MiB) Viewed 1055 times
yoshi234
- Badge Number: 234
Post
by yoshi234 » Thu Nov 21, 2019 7:04 pm
Insane shafts
y
shi - who runs their full set on 234
00 ITR #234
00 Bolt EV
21 Highlander Hybrid
Post
by RTW DC2R » Fri Nov 22, 2019 10:54 am
I currently have AutoPart International axles on #34. Theyve held up with a LOT of track time. Lifetime warranty and inexpensive. Im sure they arent the best things in the world but Ive had no issues since 2016.
Post
by coolhandluke » Mon Nov 25, 2019 6:55 pm
aw614 wrote: ↑Fri Nov 01, 2019 10:53 am
Correct,
RTW DC2R wrote: ↑Fri Nov 22, 2019 10:54 am
Excellent feedback, thank you for sharing.
Purplepassiongsr
Post
by Purplepassiongsr » Wed Nov 27, 2019 5:40 pm
What makes raxles VIR spec? I been using a set of raxles for about 8 years without issue. Would buy again.
Post
by coolhandluke » Wed Nov 27, 2019 7:07 pm
Purplepassiongsr wrote: ↑Wed Nov 27, 2019 5:40 pm
A breather at least. The grease might be higher temp too. Let me check my receipt.
*Edit - No details on receipt. The Raxles website is limited but one can email at
sales@raxles.com for more details.
Trev R
Post
by Trev R » Fri Dec 06, 2019 4:17 pm
Just replaced my first import select axle from O'Reilly's after 7 years. Went with new instead of refurbished axles and they've been fine. Only $80 an axle with warranty.
navin
Post
by navin » Tue Dec 17, 2019 8:49 am
coolhandluke wrote: ↑Wed Nov 27, 2019 7:07 pm
Raxles usually doesn't do a breather, that's a DSS thing it seems. At least my VIR spec ones don't have a breather, and I just had them rebuilt last year i think.
The VIR spec is the high temp grease used. He may use a stronger boot, not sure... Marty is cool, but he isn't sharing all his secrets
If you have a good set of OEM axles you could just repack them with high temp grease and roll.
