I hope the 3wks off isn't impacting you financially. Either way, best wishes and enjoy the wrench time.
X2coolhandluke wrote:That Carbing strut bar looks great against the VSM.
Dang rear lines also? Long lines can be a pain! Best of luck bud
Thankfully it's paid. It involves doing a little bit if work from home but it's like 2 hours per day.coolhandluke wrote: ↑Tue Mar 17, 2020 4:52 pm That Carbing strut bar looks great against the VSM.
Be aware you will not get a good ground connection though the powder coat. I would grind down the coat anywhere you will use as ground.Insidiouseg6 wrote: ↑Thu Mar 19, 2020 10:16 pm Also picked up the interior brackets from the powder coater! Dude did a great job.
Test fitted the brackets
And lastly, almost completed the brake lines, waiting on a fitting from Jegs then it should wrap that up
Appreciate the reminder! That will definitely happen when I get to connecting everything Inside the cabin.
