VSM ITR build 01-0388
Re: VSM ITR build 01-0388
Post by coolhandluke » Fri Apr 03, 2020 5:44 pm
Which Endless BBK are you running? Another user here has questions on brake pads:
viewtopic.php?f=5&t=961
Insidiouseg6
Badge Number: 01-0388
Post by Insidiouseg6 » Fri Apr 03, 2020 9:15 pm
coolhandluke wrote: Fri Apr 03, 2020 5:44 pm Which Endless BBK are you running? Another user here has questions on brake pads:
replied with the info he needed :thumbup:
coolhandluke wrote: Fri Apr 03, 2020 3:30 pm What is left after the battery is hooked up and tires are mounted?
It's still a bit of work to have a street drivable car.
Here's a quick list:
Engine swap (possibly this weekend)
Get a window guy to install front and rear windows
Bleed brakes and clutch
Get exhaust welded
Get alignment/ corner balance
Smog
Get car re tuned
Things I want but don't technically need to drive:
Spoon lip
Splitter setup for track bumper
Send K pro to get upgraded to V4
Buy a tucked engine harness (currently using OE I reloomed)
Install alarm system
Insidiouseg6
Post by Insidiouseg6 » Fri Apr 03, 2020 9:23 pm
Got the tires mounted! Rolled heR out to catch some sun while I swapped the supercharger oil and belt on my daily CRZ!
Hoping to swap the engine in over the weekend. Will update If I do
Nick MC
Post by Nick MC » Sat Apr 04, 2020 10:43 am
Beautiful! Keep up the momentum!
01-1058: Sold
'00 EBP Civic Si: Sold
'09 Civic LX-S Wife wagon
'13 Silverado Tow Vehicle
Insidiouseg6
Post by Insidiouseg6 » Sun Apr 05, 2020 2:46 pm
Nick MC wrote: Sat Apr 04, 2020 10:43 am Beautiful! Keep up the momentum!
Thanks man! Kept the momentum going and got the engine bolted in yesterday.
Gave the engine a good cleaning before installing
Raised car high enough to slide engine under
Motor in! Also installed the new valve cover
Next I plan on ordering a few AN fittings I need to get the fuel setup done as well as the power steering loop with reservoir. Also gotta replace the right rear Caliper which seems to have an issue with the internal mechanism that is needed for applying the E-brake.
Post by coolhandluke » Tue Apr 07, 2020 12:11 am
Those final shots are calendar worthy. I'm thrilled to see the motor in and the car rolling. It won't be long now. :beer:
PeteTheCarFreak
Post by PeteTheCarFreak » Wed Apr 08, 2020 5:31 am
The engine looks fantastic, good colors chosen
Insidiouseg6
Post by Insidiouseg6 » Wed Apr 08, 2020 10:08 pm
Got a few more updates...
Replaced the old compliance bushings for a set of PCI Spherical bushings.
Ran the Earl's clutch line and added a couple of P clamps to route it
Insidiouseg6
Post by Insidiouseg6 » Wed Apr 08, 2020 10:16 pm
Mounted the radiator, reservoir and added a new Mugen Cap. Still need to give it a little polish.
Made some radiator mounts but the grommets I ordered came in orange instead of black. Gonna have to check with the supplier to get black. Made them out of some random brackets I had laying around.
Post by coolhandluke » Thu Apr 09, 2020 1:48 pm
What is the logic behind the traction bar with the spherical front lower compliance pieces? I previously ran a Full-Race traction bar to assist with hard braking on track. I switched to Kingpin front lower compliance bushings and was able to drop the traction bars to cut weight and improve street comfort.
