Fluid Recommendations: (Work in progress as I research)
Section 1 - Clutch Style LSD's
ATS Metal Type D20 + D24 + ATS Type Carbon
-A.S.H 250R 85W 140
-A.S.H FSE E spec 75W 140
-BP X9140S 80W 140
-BP X9118S 75W 90
-Estremo 80W 140
-Motul 75W 140
-Motul 75W 90
-Newtech UW76 75W 140
-Neo Hi proof shock 75W 140
-Neo RHD 75W 90
-Oberon F-808 75W 140
-Oberon F-808 mineral 85W 140
-Omega 690 85W 140
-Omega 690 75W 250
-Omega 690 75W 90
-Redline 80W 140
-RESPO Le Mans 80W 140
-REPSOL 80W 140
-Subaru Stock 90W
-Sunoco 80W 140
-TOTAL Pro R 75W 140
-WAKO'S HG140R 80W 140
-WAKO'S HG250R 80W 250
Reference: ATS Carbon LSD Upgrade
Cusco Type-RS (Metal)ATS wrote: Q: Do I have to change LSD oil more frequently for the carbon LSD?
A: No. The recommended oil change interval is the same for ATS metal LSD and ATS carbon LSD. The carbon LSD went through a major upgrade in 2007 and after the improvement, the oil change is recommended every 2,000 to 3,000 miles which is same for the metal LSD. ATS carbon LSD upgrade - click for the page
More: Cusco LSD Guide
-Cusco Mission*
MFactory Metal Plate LSD:Cusco wrote: Cusco LSD Oil Change Interval
We recommend changing LSD oil following an interval;
- After brake in the new LSD = 500 miles
- 1st LSD oil change = 3,000 miles
- 2nd LSD oil change = 10,000 miles
- Regular LSD oil change = Every 10,000 miles
-Motul PA90
-Torco RTF + Torco Friction Modifier*
Mugen Metal Plate LSD
-TBD
OS Giken SuperLock
More: OS Giken - Using the Right Gear Oil and OS 250R
-Motul Competition FF 75W 140*
-Motul Gear 300 75W90 for W2W racing
Note: OS Giken does not recommend OS-250R Gear Oil, PN OS011-KA1, for FWD applications.
OS Giken wrote: Break-in fluid change interval:
-First track day or first 500-1000mi
Then:
-Every 4x track days or 10,000 mi
More:
-If fluid comes out clean at 10,000, considering extending
-If fluid comes out dirty at 10,000, consider reducing
Spoon Metal LSD
-TBD
*MFG recommended
Reference - Model Numbers
ATS Carbon
1.5 way Spec 4
DC2/EK9: CHFB87F32T
EP3/DC5: CHFB87F52T
FD2/CL7: CHFB87F92T
1.5 way Spec 5
DC2/EK9: CHFB87E32T
DC5/EP3: CHFB87E52T
FD2/CL7: CHFB87E92T
2 way Spec 4
DC2/EK9: CHFA87F32T
DC5/EP3: CHFA87F52T
FD2/CL7: CHFA87F92T
2 way Spec 5
DC2/EK9: CHFA87E32T
DC5/EP3: CHFA87E52T
FD2/CL7: CHFA87E92T
Reference - How to understand ATS part numbers:
http://ppi-ats.com/ATS%20productcode_LSD550.jpg
The last two digits specify the carbon / metal ratio of the LSD. Example, CHFB8732HB28 (carbon hybrid for DC2) has the 2 carbon discs (w/ inner edge) and 8 metal discs (w/ inner edge). CHFB8732HB46 has 4 carbon discs and 6 metal discs. Note: The side bearing for the DC5 (91005-PPS-003) is required for DC2 and EK9.
More:
-Full datasheet - Integra
-Full datasheet - Civic
MFactory
1.0 Way Metal Plate LSD
DC2: MF-TRS-10B18
DC5: MF-TRS-10K20
1.0/1.5 Way Metal Plate LSD
DC2: MF-TRS-10B18A
DC5: MF-TRS-10K20A
1.5/2.0 Way Metal Plate LSD
DC2: MF-TRS-10B18B
DC5: MF-TRS-10K20B
v2 Metal Plate LSD
DC2: MF-TRS-10B18C
DC5: MF-TRS-10K20C
Mugen
-TBD
OS Giken Super Lock
DC2: HA052-HA
DC5: HA081-HA
FK8: HA082-HA
Spoon
-TBD
Section 2 - Helical LSDs
OEM ITR:
Recommended MTF's:
-Amsoil
-GM Synchromesh FM
-Torco MTF
-Torco RTF *Can be mixed with Torco MTF 50/50
MFactory
Recommended MTF's:
-Amsoil
-Torco MTF
Change Log:
-7/9/20 - Added Helical information under Section 2
