JDM front with brake and light inspection - California
Has any done a brake and light inspection in California with JDM? Want to see if it’s possible.
Re: JDM front with brake and light inspection - California
One may have more luck with AAA if you have a membership too.RBoosted717 wrote: It will fail with the JDM front. Two main issues:
-The headlights aren't DOT approved
-The front end doesn't have amber reflectors
This applies to all states, not just CA, since it is a DOT issue (not CA.)
That being said, the CA DMV won't know unless you are ticketed or discovered during DMV inspection when you're registering the car, IE new purchased or registering from out of state. CA always checks for newly registered cars but other states may not bother looking.
California only do brake and light inspection when you recertify.
It's done through Smog Check.
Users browsing this forum: No registered users and 7 guests
