VSM ITR build 01-0388
Insidiouseg6
Badge Number: 01-0388
Re: VSM ITR build 01-0388
Post by Insidiouseg6 » Sun Apr 19, 2020 10:16 pm
Got around to tackling the tint removal off the rear window. This process was a pain in the ass but after about 4 hours we had a good looking window again
Got the track wheel/tire setup mounted.
Rays Gramlights with maxxis RC-1 tires
Picked up some Motul DOT 5.1 brake fluid. Got the clutch system bled and working properly after some pedal adjustment.
Insidiouseg6
Post by Insidiouseg6 » Thu Apr 23, 2020 4:12 pm
Got the T-bolt clamps in for the heater hoses
Replaced the overflow hose with a -6 hose
Put all of the OE window velcros and rubber spacers on
Also got a small order in from Acura.
Windows should be on next week hopefully, then I'll tackle re-looming my engine harness when the material comes in.
Insidiouseg6
Post by Insidiouseg6 » Sat Apr 25, 2020 8:33 pm
It's starting to look like a complete car now! Got the front and rear windows on. All new OEM clips and moldings of course
​​​​Roof moldings installed
Installed Hood Cowl, just waiting on the upper clips to come in
Got the rest of the T-bolt clamps in and installed on the intake. Pulled off the K&N filter and gave it a wash but forgot to snap a pic.
Car was pretty dusty from being uncovered the last few weeks so I cleaned her up with some detail spray and threw the FD2R cover on.
Wire harness material should be in early next week, I'll post updates when they do
Insidiouseg6
Post by Insidiouseg6 » Tue Apr 28, 2020 6:55 pm
Engine harness material came in yesterday so used my evening to re-loom and install the harness. Ordered the flame retardant wrap in 10 ft rolls of 1/8", 1/4", 3/8", 1/2", and 3/4".
Material.
Re loomed harness.
K tuned firewall harness grommet installed.
Harness installed on motor.
Gonna have a local fabrication guy weld my exhaust this week and will start with trying to get this car to turn over!
Post by coolhandluke » Tue Apr 28, 2020 7:46 pm
Excellent progress! You are so close, I'm excited for you. :drink:
PeteTheCarFreak
Post by PeteTheCarFreak » Tue Apr 28, 2020 11:42 pm
Looks really good man
Insidiouseg6
Post by Insidiouseg6 » Sat May 02, 2020 9:13 pm
​​Finally got the car running! I do have a few issues I need to address like a leaking brake line, a fuel issue on startup, and my trunk that seems to be stuck closed. Hopefully I'll address those this coming week.
A few pics...
A local Fab guy @gordobuilt welded up a little test pipe for the Hytech setup
Hood cowl clips came in
Found someone to make me a replacement door jam VIN tag!
And a few random shots of the car
​​​​​​​Next steps should be addressing the few issues that are currently present and a valve adjustment. Hopefully after I can get this car corner balanced and Dyno tuned!
Insidiouseg6
Post by Insidiouseg6 » Sat May 16, 2020 9:35 pm
Update!!
So fixed the issues I was having.
First, my fuel issue turned out to be a faulty AEM fuel pump. I swapped it out for a walbro and it worked like a charm! (Seems a lot of people online have issues with the AEM, so I'd be careful if you're going that route)
Second, my brake line wasn't leaking! It was just a small spill when filling the master cylinder. :hammer:
And third issue I was able to take apart my trunk actuator and notice the internal plastic piece was broken (super common for integras) so bought the Honda Odyssey actuator and stole the internals. Thanks @yoshi234 for the write up on this fix! :thumbup:
Pics....
Trunk actuator culprit (was broken into 2 pieces)
Odyssey actuator
Odyssey actuator opened up
Ended up taking the plastic piece as well as the electric motor and placed inside the ITR actuator
ITR actuator closed up and ready for install
Noticed my fuel gauge had a small leak so replaced it with a nice black gauge from checkerd sports
Picked up an aftermarket rear wiper plug and installed
Replaced the front sway bar endlinks with some Hardrace ones. Forgot to get a picture of the OEM ones, but they were shot!
Also picked up some ASR rear sway bar inserts. I will be swapping my spherical endlinks for OEM since I'm having rubbing issues with my exhaust and the OE should take care of that
Decided to be an outlaw (car is still unregistered) and take a quick trip down the road for a little photo shoot.
Still waiting on some parts to come in so I will update when they do.
Little_Nolan
Post by Little_Nolan » Sun May 17, 2020 5:39 pm
CaR looks great!
Are those Skunk 2 front LCA's? Interested in what you think of them and how they hold up.
Something to keep an eye on: I am about to swap out my hardrace front endlinks due to failure of the blue rubber part. They literally cracked apart on both sides. Noticed the failure recently - they have just shy of 6k miles on them and were installed 4.5ish years ago. I am disappointed and probably wont do any more hardrace pieces.
Insidiouseg6
Post by Insidiouseg6 » Mon May 18, 2020 11:25 am
Little_Nolan wrote: Sun May 17, 2020 5:39 pm CaR looks great!
Yeah went with S2 this time around. Will definitely give feedback on them after a couple of track days! They look to be well made.
Dang, those bushings should last a lot longer than 6k. Hmmm I will have to keep an eye on them now. Appreciate the heads up!
