Chase had posted this on HT years ago but the photos there no longer appear.
Short version: Get a door actuator from an Odyssey. Remove the one necessary part (see below) and put that into the Integra's actuator.
The infamous trunk actuator broke on my car after just a few years but never bothered to fix it until few days ago.
Close up of the broken part
Odyssey part #
The keyhole shaped piece is behind the gear circled in red. That's the only part you really need. The gears may look the same as the ones in the Integra but they are not.
The motor circled in green doesn't have to be replaced but I did anyway...just because.
Trunk Latch Fix
- Badge Number: 234
Trunk Latch Fix
00 ITR #234
00 Bolt EV
21 Highlander Hybrid
00 Bolt EV
Re: Trunk Latch Fix
Thank you for the info! need to get to this some time.
Re: Trunk Latch Fix
The chase thread is here.
viewtopic.php?f=8&t=578
On a side note I am tired of California’s silly laws with the prop 65 decals when I don’t live there.
