ITR Door Hinges
Humpie56
ITR Door Hinges
Post by Humpie56 » Fri Nov 17, 2017 8:42 pm
Anyone have the Drivers Hinges wear out. My lower one has play and recently it doesn’t like to close properly because of it. I wonder if anyone has the Japanese Parts CD and if they are the same parts since some companies sell the JDM Hinges.
Current
1997 Type-R #00051
1999 LS-R 4dr JDM 98spec w/CTR Cam
Re: ITR Door Hinges
Post by Dave7CDMTYPER » Fri Nov 17, 2017 8:53 pm
I'd think the jdm hinges would be the same. Just guessing though.
Re: ITR Door Hinges
Post by jayhaire » Fri Nov 17, 2017 10:38 pm
I have the JDM EPC available. Do you have a part number to compare?
Humpie56
Re: ITR Door Hinges
Post by Humpie56 » Fri Nov 24, 2017 6:58 pm
Is that a Japanese Parts Catalog?
Looks like both doors use the same two hinges just in reverse!
67410-ST7-505ZZ
67450-ST7-505ZZ
Current
1997 Type-R #00051
Re: ITR Door Hinges
Post by Stin1 » Sun May 17, 2020 11:13 am
So my door decided to sag and I can feel play. I can lift it up and it closes properly. From researching the hinge bushing fails and causes this . The lower hinge I can see doesn’t appear to even have the bushing any longer. The part numbers for the type R is discontinued. It seems the other models have a different part number and appear to be available.
Any one know why they have a different part number, or if I can use the rs-gsr equivalent? I also tried a Japanese catalogue search. That got confusing. It looks like that catalog showed maybe left and right side using different part numbers that are also different from the U.S type R part numbers .
Re: ITR Door Hinges
Post by Stin1 » Sun May 17, 2020 11:15 am
Re: ITR Door Hinges
Post by Stin1 » Sat May 23, 2020 1:56 pm
Crickets in here. I referenced the jdm part numbers for the type r assigned in the catalog , I found they correspond to a 1990 legend and 90 - 96 integras in the U.S . The superseded part number in the U.S is the same part number as every other model except Acura didn’t list the Usdm type R with the superseded part number. I read a post somewhere that Acura fubared the catalog ?? Any way I have the some pics for you guys of the replacements. Remember these were painted. You only get black no options on color.Image
Re: ITR Door Hinges
Post by Stin1 » Sat May 23, 2020 1:58 pm
There’s bushings that deteriorate causing the door to sag . You can see them in the pic .
Re: ITR Door Hinges
Post by Stin1 » Sat May 23, 2020 2:00 pm
There’s a c clip holding the pin . Might be possible to change the bushing and keep the original hinges and pin ? That’s what I see on other models . Acura or Honda doesn’t sell those .
Re: ITR Door Hinges
Post by Stin1 » Tue May 26, 2020 4:23 pm
Dc2productions was kind enough to send me some pics of his 97 hinges. Other than paint, I notice his pins have a slightly tip different tip .
Users browsing this forum: No registered users and 6 guests
