iPhone hookup to stock radio
Re: iPhone hookup to stock radio
Post by Stin1 » Thu May 28, 2020 4:38 pm
The alpine round was also to have l&r swapped vs. the Honda version on the cable.
navin
Post by navin » Thu May 28, 2020 9:58 pm
Using this hooked up the OE radio: http://www.oemautosound.com/p-8-honda-a ... n-aux.aspx
Using their RCA cables to AUX input cable as well -- tried swapping the red/white plugs on RCA input and still no change in sound output. Also when using the radio it only sounds like its coming from the driverside front as well.
navin
Post by navin » Thu May 28, 2020 10:01 pm
Stin1 wrote: Thu May 28, 2020 4:38 pm The alpine round was also to have l&r swapped vs. the Honda version on the cable.
What's the alpine round?
Post by Stin1 » Thu May 28, 2020 11:04 pm
navin wrote: Thu May 28, 2020 10:01 pm
There’s 2 cd changer ports . The later Hondas use a square plug like every Honda connection. The 98 uses a round plug. It’s a alpine plug used in many other models , including European radios.
Post by Stin1 » Thu May 28, 2020 11:09 pm
Here’s the alpine or itr port for a cd changer or tape deck.
Post by Stin1 » Thu May 28, 2020 11:10 pm
* for
Post by aw614 » Fri May 29, 2020 1:15 am
hmm that should have worked with the audio, Im curious why you are having issues. This was the one I am using on my car
https://www.blitzsafe.com/catalog/hon-/-aux-v-1.html
Looks like blitzsafe has a few different options
https://www.blitzsafe.com/catalog/1992-1998.html
The picture stin1 is showing what I have on my 2000 integra.
navin
Post by navin » Fri May 29, 2020 8:06 am
Actually you are correct -- I ordered from oemautosound, but was shipped a Blitzsafe item. This one: https://www.blitzsafe.com/catalog/hon-/-aux-v-1.html
I'm almost thinking the internal amp in the ITR radio is busted?
edit: and yes I've tried to adjust the balance as well to test if that was the problem :drink:
