DIY Vapor Barrier
yoshi234
Badge Number: 234
DIY Vapor Barrier
Post by yoshi234 » Tue Jun 09, 2020 9:43 pm
Honda has discontinued the vapor/moisture barrier so decided to make my own. Fairly easy process :thumbup:
Before:
I found that the easiest way to remove all the gooey mess was to scrape off as much as possible with an old key card/credit card. Then wet down some paper towels with WD-40 and pat the residuals to loosen. Go back over while wiping. Do a final cleaning w/ degreaser or rubbing alcohol.
Cut out a piece of 6mil poly sheeting. 37x18" Tape onto door and trace out the area where the butyl tape will be applied.
Cut about an 1" outside those lines. Apply the butyl tape in the recessed area and press on new vapor barrier. Anywhere a hole needs to be cut, I placed clear tape over the area to reinforce it. Done :beer:
Parts used:
6mil poly sheeting
https://amzn.to/2XJ1jsr
butyl tape
https://amzn.to/2AeoLok
00 ITR #234
00 Bolt EV
21 Highlander Hybrid
:geek:
Re: DIY Vapor Barrier
Post by Stin1 » Tue Jun 09, 2020 9:57 pm
What was the temperature? I did mine in 110 + temps, and the humidity was high. The floor was and everything had goo everywhere. Every other 96-01 Honda they are like dried bubble gum.
Little_Nolan
Post by Little_Nolan » Tue Jun 09, 2020 10:00 pm
Hey this is pretty neat. I have always tried to reuse or "salvage" the factory stuff. Good thinking!
Thanks for posting this.
Post by Dave7CDMTYPER » Tue Jun 09, 2020 10:41 pm
Very helpful! Thanks for the links btw. Ordered the parts, will need to do this on my gs-r driver's door sometime.
You have type r speakers too. :trophy:
yoshi234
Badge Number: 234
Post by yoshi234 » Wed Jun 10, 2020 9:04 am
Stin1 wrote: Tue Jun 09, 2020 9:57 pm What was the temperature? I did mine in 110 + temps, and the humidity was high. The floor was and everything had goo everywhere. Every other 96-01 Honda they are like dried bubble gum.
I think it was low 80's when I did this? Driver's side was worse where the goo had slid down into the door. :?
00 ITR #234
00 Bolt EV
:geek:
yoshi234
Badge Number: 234
Post by yoshi234 » Wed Jun 10, 2020 9:10 am
Dave7CDMTYPER wrote: Tue Jun 09, 2020 10:41 pm Very helpful! Thanks for the links btw. Ordered the parts, will need to do this on my gs-r driver's door sometime.
I forgot to include that any holes I made was reinforced with packing tape to try and prevent tearing once it's all put back together.
The speakers have held up nicely over the years :thumbup: Type R in front, Type S for the rears. :mrgreen:
00 ITR #234
00 Bolt EV
:geek:
Post by coolhandluke » Wed Jun 10, 2020 10:25 am
Excellent write up Yoshi! This item has been longstanding on my to-do list. I was able to secure OEM vapor guards before they went discontinued, but I wasn't sure on both how to best to remove the goo and what to reseal with. I owe you :beer: .
Extra credit for coming up with a suitable replacement for Honda discontinuing this part. The community needs more people like yourself as Honda makes it harder for us to maintain these cars. :thumbup:
Post by Stin1 » Wed Jun 10, 2020 11:11 am
The plastic Honda uses to wrap their windshields is similar in material.
JDMJNKY
Badge Number: 0874
Post by JDMJNKY » Thu Jun 11, 2020 12:58 am
:trophy: :trophy: :trophy: :trophy:
