98-0413
Re: 98-0413
Rcomps for a street car?
I dig the CE's. They will be mine one day. I will also go 16''s due to availability and clearance.
Did you paint the bay in the GS-R?
Re: 98-0413
Been following you on Instagram and never realized you were on this site as well. Car looks great.
Re: 98-0413
Yeah my buddy works at Toyo.coolhandluke wrote: ↑Mon Jun 11, 2018 10:40 am Rcomps for a street car?
Yes I did paint the bay, it came out meh, better than before though.
Re: 98-0413
Check out the Proxes R1R next time. They will save $ and last longer, which still being a sticky tire at 200tw.
Re: 98-0413
I actually have those on my SW388's.coolhandluke wrote: ↑Thu Jun 21, 2018 2:12 pmCheck out the Proxes R1R next time. They will save $ and last longer, which still being a sticky tire at 200tw.
Re: 98-0413
Fortunately I don't have any updates on my ITR. I say fortunately because that means the car is doing amazing!
I do have an update on my K20R Swapped GSR. It's finally running!
Here is the full mod list for those interested:
1994 Acura Integra GSR
Engine Bay
K20R Complete Swap
Rywire Engine Harness
Rywire Conversion Harness
Rywire Charge Harness
Rywire Ground Kit
Hondata K-Pro V4
Hasport Motor Mounts
Checkerd Sports Coil Cover
R Crew Racing Oil Cap
R Crew Racing 4-2-1 Header
R Crew Racing 3” Exhaust
Karcepts Throttle Bracket
Karcepts Clutch Line
Karcepts Fuel Rail
Aeromotive Fuel Pressure Regulator
Aeromotive Fuel Pressure Gauge
Walbro 255LPH Fuel Pump
Hybrid Racing Tucked Fuel Lines
Hybrid Racing Radiator Hoses
K Swap Koyo Radiator
ASC Speed Metal Cold Air Intake
OEM RBC Intake Manifold
OEM CL7 Throttle Body
OEM GSR Throttle Cable
OEM EP3 Idler Pulley
Exterior
JDM ITR HID Front End Conversion
Spoon Sports Carbon Fiber Hood
Spoon Sports Carbon Fiber Lip
Spoon Sports Carbon Fiber Mirrors
J’s Racing Carbon Fiber Air Duct
JDM ITR Rear Spoiler
UKDM ITR Tail Lights
UKDM ITR Side Markers
Welded Side Moldings
Welded Antenna Hole
Welded Front Emblem
Welded Rear “Acura” Emblem
Welded Rear Water Squirter
Interior
Works Bell Short Boss Hub
Works Bell Quick Release
Works Bell Quick Lock
Spoon Sports Steering Wheel
Spoon Sports Rear View Mirror
Checkerd Sport Shift Knob
K-Tuned Race Spec Shifter Cables
R Crew Racing Shifter Plate
Recaro Pole Position Bucket Seats
Recaro Side Protectors
USDM ITR Rear Seats
USDM ITR Floor Mats
USDM ITR Door Panels
USDM ITR Amber Clock
USDM ITR Armrest Lid
USDM ITR Carbon Fiber Dash Pieces
JDM ITR Carbon Fiber Window Switches
JDM ITR Red Stitched Shift Boot
JDM ITRx Pedal Set / Sergeant Dead Pedal
JDM ITR Foglight Switch
JDM ITR E-Brake Handle
JDM ITR Door Handle Bezels
CDM Airbag Delete Tray
Wheels | Suspension
Volk Racing CE28N (16x8 +35)
Toyo Proxes R888R - 225/45/16
Spoon Sports Strut Tower Bar (Front)
Spoon Sports Strut Tower Bar (Rear)
GC/Koni Coilovers & Extended Top Hats
JDM ITR 36mm 5 Lug Conversion
JDM ITR 23mm Rear Sway Bar
Goodridge SS Braided Brake Lines
Skunk2 Pro Series+ Front Camber Kit
Skunk2 Hard Anodized Rear Camber Kit
Hardrace Front Lower Ball Joints
Function7 Rear Lower Control Arms
Function7 Rear Subframe Brace
Engine Bay
K20R Complete Swap
Rywire Ground Kit
Hondata K-Pro V4
Karcepts Fuel Rail
Exterior
Welded Antenna Hole
Welded Front Emblem
Interior
USDM ITR Rear Seats
USDM ITR Floor Mats
Wheels | Suspension
Re: 98-0413
Your GSR reminds me of mine, so many “regerts”. Nice job btw, seems like a fun drive from your IG vids.
Re: 98-0413
Oh wow, I totally forgot about this thread. Fast forward to 2020. I sold the R.
During the past 2 years I've had an E46 M3, Scat Pack but now I have a Hellcat.
I still have my GSR that I completely took apart to rebuild but is currently on the back burner.
98-0413 went to SoCal and I heard it's back up here in NorCal but I'm not sure who the new owneR is!
Thanks everyone for the awesome memories in my R!
Re: 98-0413
Looks amazing. Is the hellcat a manual?
Re: 98-0413
Thanks. It's not. Charger's only come with an 8AT, you can get a Challenger (2dr) in a 6MT but they are starting to veer away from MT's as they come out with newer ones for 2021.
