WTB breather pipe
WTB breather pipe
looking for breather pipe from intake pipe to valve cover 17135-P73-010
Re: WTB breather pipe
Just bought a GSR one from HMO, from what I read it seems that it’ll be a bit longer than the ITR one. I’ll update once it arrives! GLWF
Apparently the B16 breather pipe worked for my friend on his EG hatch with the ITR intake arm and b16a, another option to consider.
Did you ever got the GSR part did it worked? Anyone know the B16 part number?
I faced this myself and bought a used JDM ITR breather tube from a UK eBay seller R-motion. I test fit my friends JDM 96 ITR tube first. The JDM DC2R breather tube and hoses is nearly identical. It appeared to be slightly shorter to the intake tube but it’s not noticeable. Note that the seller mistakenly sent me the UKDM breather tube which has an extra bracket on it. I mailed it back and he sent the correct one.
I refinished my tube in low gloss black and it looks fresh and OEM.
https://www.r-motion.co.uk/
Untitled by touringteg, on Flickr
CW ITR 01-1233 CDM Sold
CW ITR 98-0635 CDM
CW CTR 17-01818 CDM
CW ITR 98-0635 CDM
CW CTR 17-01818 CDM
Do you happened to know which one is from this pic?
- Screen Shot 2020-11-02 at 12.34.15 PM.png (468.38 KiB) Viewed 1596 times
Yes I do since I have spent way too many hours researching the DC2 ITR breather tube (I have 3 or 4 spares from various Hondas that do not fit)
The upper right in the photo is the UKDM ITR breather tube with the extra square bracket. Note that the UKDM coolant hoses are orientated in different directions that JDM/USDM.
The lower left one (the straight rubber hose piece has been cut short) is the JDM ITR breather tube. Fits both JDM and USDM/CDM cars. The coolant hoses are the correct orientation. If I remember correctly the USDM/CDM has a longer end with an angle cut to go into the air intake tube but JDM still works fine.
CW ITR 98-0635 CDM
CW CTR 17-01818 CDM
CW ITR 98-0635 CDM
CW CTR 17-01818 CDM
Thanks wow you are the expert!
I ordered lets see how it goes when it arrives
