What ABS filler did you use? I bought a set of UKDM tail lights and a post was broken in transit. I wonder if I could try your trick on repairing the post.
@coolhandluke I bought a polyvance airless welding kit. Im very happy with it but it does take a bit of practice to get used to and patience to finesse to get acceptably tidy.
I think it will be useful for a lot of repairs like your broken clip and torn plastics that are pretty common on our cars as they get older. I already have a list of minor repairs I know I can do now.
While practicing to weld the replacement section of dash I shaped a bunch of the filler in to the old dash section to see if it could really be used to rebuild a clip. I’m amazed it’s as strong as original even with such a quick sloppy job.
![Image](//uploads.tapatalk-cdn.com/20201119/679ee790a0560a64395e9fc5478b0c82.jpg)
A portion of the clip was entirely broken out before the test, and I just free hand melted the filler into a rough shape to get a sense for the material.
![Image](//uploads.tapatalk-cdn.com/20201119/e8b0965887b0fb533ec46c46c7beb6b8.jpg)
The abs filler material feels very rubbery when it’s warm but once cool feels the same as our interior plastics so don’t judge too quickly, give it a couple minutes once you’re done.
Here’s the link to the kit on Amazon.
Polyvance 5700HT Mini Weld Model... https://www.amazon.com/dp/B00IEX6NME?re ... b_ap_share
![Image](http://uploads.tapatalk-cdn.com/20201119/679ee790a0560a64395e9fc5478b0c82.jpg)
![Image](http://uploads.tapatalk-cdn.com/20201119/e8b0965887b0fb533ec46c46c7beb6b8.jpg)
One of the next things on my to do list for 01-0386 is getting the rear together where I just have things basically hanging in place currently.
The original steel bumper had rust issues so a long time ago I picked up a used replacement in good condition. The replacement was from a green Integra so today I fixed that.
In the next couple days I’ll get the hardware together and shoot to start getting it together properly next week.
![Image](//uploads.tapatalk-cdn.com/20201119/8342f6e98320e07c5c2d87ef39e034b1.jpg)
![Image](//uploads.tapatalk-cdn.com/20201119/845ba150001a4df934e1a7717651e32a.jpg)
![Image](http://uploads.tapatalk-cdn.com/20201119/8342f6e98320e07c5c2d87ef39e034b1.jpg)
![Image](http://uploads.tapatalk-cdn.com/20201119/845ba150001a4df934e1a7717651e32a.jpg)
Pretty successful day
Third taillight and hatch plastics went in.
Ended up doing a bit more plastic welding to repair a torn tab for one of the hatch side covers.
Turns out the plastics are actually polypropylene (which the polyvance unit has a setting for and comes with pp filler too). Repair worked out near perfectly.
Inspired by some momentum, I was able to harvest some mounting hardware for the rear bumper and things just kept going pretty smoothly so....well here’s the finished product.![Image](http://emoji.tapatalk-cdn.com/emoji7.png)
![Image](//uploads.tapatalk-cdn.com/20201121/56b26d000382ad4a9c5be399daa4c9f0.jpg)
Hatch plastics on
![Image](//uploads.tapatalk-cdn.com/20201121/b2293d71e6b36db924755cd67d8b906f.jpg)
New license plate lights on
![Image](//uploads.tapatalk-cdn.com/20201121/f726f743c0fa30d3cb186d58e3ba2d65.jpg)
Rear bumper beam mounted
![Image](//uploads.tapatalk-cdn.com/20201121/0b0bf32e2fd6114870863425e404a0fc.jpg)
Bumper beam cushions (left was discontinued so is original and pretty disintegrated, right I managed to get new)
![Image](//uploads.tapatalk-cdn.com/20201121/bf27d78f8b7f540c123a5fe58d10aaf7.jpg)
Bumper skin and filler
![Image](//uploads.tapatalk-cdn.com/20201121/b3b6dbb67cb3ee838029bfc2052fc12f.jpg)
Taillights (need to polish the right some but both are mounted with oem seals)![Smile :)](./images/smilies/icon_e_smile.gif)
![Image](//uploads.tapatalk-cdn.com/20201121/50a59b02166def7df191b4083ea41064.jpg)
It was a good day!
Just as good is that this means I’m a few minor things away from starting work on getting side plastics back in!
![Wink ;)](./images/smilies/icon_e_wink.gif)
![Image](http://uploads.tapatalk-cdn.com/20201121/56b26d000382ad4a9c5be399daa4c9f0.jpg)
Hatch plastics on
![Image](http://uploads.tapatalk-cdn.com/20201121/b2293d71e6b36db924755cd67d8b906f.jpg)
![Image](http://uploads.tapatalk-cdn.com/20201121/f726f743c0fa30d3cb186d58e3ba2d65.jpg)
![Image](http://uploads.tapatalk-cdn.com/20201121/0b0bf32e2fd6114870863425e404a0fc.jpg)
![Image](http://uploads.tapatalk-cdn.com/20201121/bf27d78f8b7f540c123a5fe58d10aaf7.jpg)
![Image](http://uploads.tapatalk-cdn.com/20201121/b3b6dbb67cb3ee838029bfc2052fc12f.jpg)
![Image](http://uploads.tapatalk-cdn.com/20201121/50a59b02166def7df191b4083ea41064.jpg)
It was a good day!
Upper side plastics are in. Yet another broken tab repaired with the plastic welder, so all clip are in place!
![Image](//uploads.tapatalk-cdn.com/20201121/a3416e5ae4a265ea402e5e1e3e7dfe6e.jpg)
![Image](//uploads.tapatalk-cdn.com/20201121/71762677c6c7a055af2b7bd1b5f2fe8a.jpg)
Unfortunately the installer that did the glass let the adhesive come up too high for the rubber trims in a couple places so I’ll have to trim the adhesive down with a razor before the rubber trims go into place properly.
![Image](http://uploads.tapatalk-cdn.com/20201121/a3416e5ae4a265ea402e5e1e3e7dfe6e.jpg)
![Image](http://uploads.tapatalk-cdn.com/20201121/71762677c6c7a055af2b7bd1b5f2fe8a.jpg)
Ok one more update today ![Image](http://emoji.tapatalk-cdn.com/emoji38.png)
Right side plastic in place!
![Image](//uploads.tapatalk-cdn.com/20201122/9e57619faea0ea40e49c68db5cdefab0.jpg)
![Image](http://uploads.tapatalk-cdn.com/20201122/9e57619faea0ea40e49c68db5cdefab0.jpg)
This sounds like a great feeling! I'm having flashbacks to ~2008 when I was doing final assembly for my rebuild. That's quite a feeling, the home stretch is within sight!
I wasn't aware of the rear bumper foam being discontinued.
![Confused :?](./images/smilies/icon_e_confused.gif)
I feel like I saw this in Disney’s Cars before ![Image](http://emoji.tapatalk-cdn.com/emoji1787.png)
Worked though. Our trees got trimmed up, my wife got to drive the ITR, and the ITR and the LS shell are both tucked back away.
I did have to ask her not to shift into gear at 3.5k. The Ogura clutch takes some finesse, or be ready to launch.![Wink ;)](./images/smilies/icon_e_wink.gif)
![Image](//uploads.tapatalk-cdn.com/20201124/6425b93c8a9b910557b0bc3890e75589.jpg)
Yeah I busted another caster off the dolly. #myweldingsucks but fortunately had the wood furniture dolly on hand, so all’s well.
![Image](http://uploads.tapatalk-cdn.com/20201124/6425b93c8a9b910557b0bc3890e75589.jpg)
Aaaand
Bits from powdercoating
![Image](//uploads.tapatalk-cdn.com/20201124/8f356e585230f70367ddda1051e31e96.jpg)
The shop (powder coat unlimited) did an amazing job, no chipping at the joints, even the backsides look fantastic.
![Image](//uploads.tapatalk-cdn.com/20201124/98a5986f614144b72fe6ea7f2ed4b61c.jpg)
![Image](http://uploads.tapatalk-cdn.com/20201124/8f356e585230f70367ddda1051e31e96.jpg)
![Image](http://uploads.tapatalk-cdn.com/20201124/98a5986f614144b72fe6ea7f2ed4b61c.jpg)
Oh wow, those look fantastic! I'm taking notes for my car. ![Drunk :beer:](./images/smilies/embeer.gif)
