IIRC it’s a standard oem unit, I didn’t go with a unit that would open before 170f.coolhandluke wrote: What thermo is installed?
The fan switch is just a cheap Mishimoto and that should turn the fan on at 176f.
You’re likely right on both counts.Dave7CDMTYPER wrote:One option for the heat shield exhaust rattle is to remove the heatshield. I had to do this with mugen cat back twinloop.
It takes a while for the fan to come on with these cars. I had to drain and refill coolant on my gs-r recently, and it seemed to take forever for fan to come on when bleeding the system.
Yep going to be my standard practice now for all critical fasteners.noahf wrote:grab a yellow paint pen and mark the bolts after you torque them. It lets you know they are torqued and if you also mark the side/mounting surface you can see if it has backed out any.
