WTB: Type R catalytic converter
Looking to purchase a New, OEM USDM
Type R catalytic converter. Part Number:
18160-P73-A00
Please contact if you are ready to sell.
Thank you community
18160-P73-A00
Thank you community
Re: WTB: Type R catalytic converter
I wish you luck. This might be the hardest of all the USDM parts to find.
I received the original cat with my 98 CDM but unfortunately it is loose inside. A friend even gave the original cat heat shields top and bottom.
CW ITR 01-1233 CDM Sold
CW ITR 98-0635 CDM
CW CTR 17-01818 CDM
CW ITR 98-0635 CDM
CW CTR 17-01818 CDM
They are out there, it’s just a matter of the individual letting go of it, why I wrote if you’re ready to sell ; )
New ones are out there? I bet Acura ate the new ones up on warranty replacements . If they are out there does anyone have a picture ?
I feel like there are very few people who bought a new OEM USDM cat and put it in storage. And used one were likely recycled for for cash.
I will likely have a custom cat made to replace my worn out OEM cat.
CW ITR 98-0635 CDM
CW CTR 17-01818 CDM
CW ITR 98-0635 CDM
CW CTR 17-01818 CDM
Any recs of aftermarket ones?
Both OEM heatshields show available for the USDM ITR. I have yet to find a quality aftermarket cat, especially one that isn't raspy. I went so far as to replace the entire exhaust with a JDM ITR setup from the header back, and had a bung made in the cat for the O2, no CEL's yet.
OEM cat still shows available for 99-00 Civic Si; part number: 18160-P2P-A00
I'm sure there is a way to make that work considering the Si was a B series with just a little less power than the C5.
My next custom set up will try a GESI “gsport” cat. It’s certified to federal standards, uses a metal honeycomb (vs ceramic), and the housing is stainless steel. Use of the metal honeycomb allows better flow (300 cell). The unit I picked up is 4” x8” (2.5” in/out).
Paperwork with it cautions against heating above 900c while tuning, while it’s rated to this temp sustained exposure will cause damage.
Looks like it’s $330 for the cat itself from Hpt auto and of course this still needs someone to weld flanges and an O2 bung.
A member on here makes custom high quality cats . I can’t recall his name .
