Good stuff Free for pickup
(Pending)Apexi WS Noir 94-98 GSR catback exhaust.
Has only seen ~300mi. in good shape but may not have all bolts etc and will have some cosmetic scratches, staining, etc from use. Flows well and sounds good just not what I want to run.
(Pending)Password:JDM carbon intake GSR never used may need coupler clamps. Includes filter.
GSR intake arm
(Pending)Oem oil pan (basically brand new came with the assembled block and I’m now running a Mugen baffled pan) it’s been sitting so needs a wash that all
Jackson boost controller
Was included with my jrsc kit but I don’t have a use for it. No idea if it works, but no reason to suspect it doesn’t.
Unknown ecu with s300v1
Probably has battery issue as it’s been unplugged for years. Never tested appears in good shape otherwise.
(Pending) 1320? 2.5” test pipe (never used/mounted)
(Pending) Harbor freight engine stand (great shape, you just need appropriate bolts to mount your block) mounts great with p72 blocks it’s what I used to assemble.
(Pending)Exedy OEM replacement clutch and (standard) pressure plate
ACT streetlight flywheel
Had these on for <5000mi held 213whp without issue and no idle/shift issues. Probably perfect for stock ITR with oem flywheel discontinued.
(Pending)Brand new never used lugs (16) with with locks (4)
3” flex coupler (at least 2 available) new in box with band clamps
Located in Sherman Oaks, CA and I want it out of my garage. I’m terrible at actually shipping and due to size/weight I’m not going to.
Thanks,
Alan
GSR intake arm
Thanks,
Alan
- IMG_5301.jpg (1.84 MiB) Viewed 2210 times
Re: Good stuff Free for pickup
Why is all the good stuff on the other side of the country? If you were remotely local I could use all of it, minus the engine stand.
- oddomatik
- Badge Number: 98-0542
DAMMIT I just walked in the door after an 8 hour drive from delivering a GS-R engine to a friend and drove right through your area haha. I would have taken the clutch lugs and engine stand. I may send him the link as he might be able to use some parts to take his H2B back to smoggable if you are open to members outside this community taking advantage of your generous offer.
As long as they are cool, decent characters, and not a pain in the a$$ parts are open to anyone who can pick them up.oddomatik wrote:DAMMIT I just walked in the door after an 8 hour drive from delivering a GS-R engine to a friend and drove right through your area haha. I would have taken the clutch lugs and engine stand. I may send him the link as he might be able to use some parts to take his H2B back to smoggable if you are open to members outside this community taking advantage of your generous offer.
PM'd about items, im pretty local to you.
Thanks,
Thanks,
- Dc2-ProductionS
- Badge Number: 97-00012
grrrrr. Could use that Hondata V1 if it wasnt 3k miles away!
Willing to purchase or pay for shipping if still available.
Dc2
Dc2
Sorry I think everything from this round has found a home.
I heart the Type R Expo community.
