Tips on looking at carbon/oil build up on exhaust valve ports?
I'm beginning the process to remove my head (taking my time removing a few parts here and there) and I had a good look at the exhaust valve ports and have some noob questions about what I am seeing.
My cylinder 4 exhaust port looks like this Cylinder's 1-3 exhaust ports for the most part look like this one cylinder. Cylinder 4 doesn't look good and looks like oil is on both valve stem. Could piston rings cause what I am seeing or is that going to be valve guide/seals? The spark plug was getting wet with oil and fouling quickly.
But on cylinders 1-3 is that normal or should it be cleaner that that?
When I pull the head out, am I going to notice any other signs of this on the cylinders? scoring cylinder walls and what about the top of the pistons? Carbon fouled? What else should I look for?
This is my first time with diagnosing this and hoping anyone with experience can chime in.
Re: Tips on looking at carbon/oil build up on exhaust valve ports?
What’s a compression test say?aw614 wrote:I'm beginning the process to remove my head (taking my time removing a few parts here and there) and I had a good look at the exhaust valve ports and have some noob questions about what I am seeing.
If rings I’d think compression would be low in that cylinder. If compression is good or the same as other cylinders at least, then it’s not something on the cylinder side of the valve.
I need to get it back from a friend as he hasn't returned it backaklackner wrote: ↑Fri Feb 18, 2022 6:45 pmWhat’s a compression test say?aw614 wrote:I'm beginning the process to remove my head (taking my time removing a few parts here and there) and I had a good look at the exhaust valve ports and have some noob questions about what I am seeing.
![Mad :x](./images/smilies/icon_mad.gif)
Could I do anything with a leak down tester? I have the header off the car and valve cover unbolted, that shouldn't impact results?
I’d think leak down should provide pretty direct indication if rings are sealing or losing pressure worse in a cylinder.
- Badge Number: searching
Leakdown test for sure, its a much better method for determining what the health of the engine is.
Valve seals are a very common wear item on any Honda, especially if they have never been changed. But judging by those photos it could be the oil control rings have lost their tension.
Most of the times I've seen the exhaust port looking that bad it's been because of ring issues. I've personally never seen a bad valve seal cause that much oil leakage. Only seen light seepage residue on the valve and guide if it's valve seal related.aw614 wrote: ↑Thu Feb 17, 2022 11:13 pm I'm beginning the process to remove my head (taking my time removing a few parts here and there) and I had a good look at the exhaust valve ports and have some noob questions about what I am seeing.
Apply air pressure to the cylinder with your leak down tester and I bet you hear air like crazy coming into the crankcase past the rings. You can listen for air coming through the intake manifold, exhaust, crankcase to pin point leaks in intake valves, exhaust valves, piston rings.
I think you might be right its the rings. I just did a leakdown test, cylinders 1-3 all were within 90-95 psi out of 100 psi per my leakdown tester. It did feel like the exhaust valves with the header out was leaking a bit of air from cylinder 4. Might need to run it again to see from the breather and intake...DC231 wrote: ↑Mon Feb 28, 2022 11:40 am Most of the times I've seen the exhaust port looking that bad it's been because of ring issues. I've personally never seen a bad valve seal cause that much oil leakage. Only seen light seepage residue on the valve and guide if it's valve seal related.
Cylinder 4, was 25-30 psi out of 100 psi so like 70% leakage
![Shocked :shock:](./images/smilies/icon_eek.gif)
I don't think a valve guide or a valve seal could cause that much leakage can it? Cylinder 4 is the one that gets beat up the most due to heat and being further away correct?
only way would be is if you have a burnt out valve. 4 is the furthest away from the oil pump so it can be more susceptible to oiling issuesaw614 wrote: ↑Fri Mar 04, 2022 2:23 pmI think you might be right its the rings. I just did a leakdown test, cylinders 1-3 all were within 90-95 psi out of 100 psi per my leakdown tester. It did feel like the exhaust valves with the header out was leaking a bit of air from cylinder 4. Might need to run it again to see from the breather and intake...DC231 wrote: ↑Mon Feb 28, 2022 11:40 am Most of the times I've seen the exhaust port looking that bad it's been because of ring issues. I've personally never seen a bad valve seal cause that much oil leakage. Only seen light seepage residue on the valve and guide if it's valve seal related.
Cylinder 4, was 25-30 psi out of 100 psi so like 70% leakage![]()
Welp took the head off today, and it doesn't look like the valves were burnt, but the valves and the pistons being carbon are caked black
Valves Block, The wet oil on cylinder 4 I think was from the oil dripping from pulling the head
At the Honda dealership they re-ring engines all the time without pulling the engine block or doing any machine work from oil consumption. The ring gaps all fall in line over time and cause oil consumption. If the cylinder walls look good they just pull the Pistons and install new rings. I've seen it done over a dozen times.aw614 wrote: ↑Sat Mar 12, 2022 7:01 pmWelp took the head off today, and it doesn't look like the valves were burnt, but the valves and the pistons being carbon are caked black
Valves
