Spoon Twin-Block Brake Caliper Wheel Clearance List
audipwr1
Re: Spoon Brake Caliper Wheel Clearance List
Post by audipwr1 » Fri Jul 15, 2022 7:48 pm
Ok so update here
I got Rota Slipstreams 16x7s with 45 offset and the twinblock calipers
Any idea on a good spacer for it? Otherwise will do some measurements and let the group know
Post by coolhandluke » Mon Jul 18, 2022 11:19 am
audipwr1 wrote: Fri Jul 15, 2022 7:48 pm Ok so update here
The Spoon SW88's in 16x7'' +45 clear. Rota 15x7's cleared, but I forget if they were +45 or +42. The easy test will be to test mount and inspect clearance.
audipwr1
Post by audipwr1 » Tue Aug 02, 2022 5:30 pm
It takes a 10mm spacer to clear - sad but true
Post by coolhandluke » Wed Aug 03, 2022 4:20 pm
audipwr1 wrote: Tue Aug 02, 2022 5:30 pm It takes a 10mm spacer to clear - sad but true
Thank you for confirming, I've updated page 1 with your contribution.
Hazz
Re: Spoon Twin-Block Brake Caliper Wheel Clearance List
Post by Hazz » Wed May 24, 2023 6:21 am
The JDM 96 spec 15” wheels (4x114.3) fit over twinblocks with a 15mm spacer, plenty of clearance so could maybe get away with 13 or maybe even 12mm.
Hazz
Post by Hazz » Wed May 24, 2023 10:50 am
Also, slightly off topic… if anyone has a pic of the oem spring clip mod for these I’d much appreciate it :)
I’ve found some snippets of info on other forums but failing to find the nugget I’m after due to old dead picture links.
Just trying to get rid or at least reduce the floating pad chatter (regretting my choice of grooved and drilled discs now atm).
Hazz
Post by Hazz » Wed May 24, 2023 10:51 am
Reason: duplicate
Post by coolhandluke » Wed May 24, 2023 11:22 am
Hazz wrote: Wed May 24, 2023 6:21 am The JDM 96 spec 15” wheels (4x114.3) fit over twinblocks with a 15mm spacer, plenty of clearance so could maybe get away with 13 or maybe even 12mm.
Added to the first page, thank you for contributing this knowledge. :thumbup:
Hazz wrote: Wed May 24, 2023 10:51 am Also, slightly off topic… if anyone has a pic of the oem spring clip mod for these I’d much appreciate it :) ...
I understand the ask, as the lack of spring clip in my Spoon Twinblocks led to pad chatter. However, my track pads made more noise, so I didn't do that mod. The noise got worse when I went to a BBK.
Badge Number: 98-9425
Post by 98-0425 » Wed Sep 27, 2023 10:20 pm
Does anybody have an idea on the size of spacer for UKDM 15"s?
