Oem radio / usb input
audipwr1
Post by audipwr1 » Thu Sep 08, 2022 7:52 pm
Anyone know of / have used a company that can make a usb input for oem radio?
I want oem look but play iPhone
Thanks
shuttlepilot
Re: Oem radio / usb input
Post by shuttlepilot » Thu Sep 08, 2022 9:48 pm
You can try this: https://gromaudio.com/store/usb_adapter ... r-kit.html
I can't vouch for the USB adapter, but I have a Grom BT3 bluetooth adapter that works okay. The only annoyance is when hitting the ignition key, the radio cuts out which tells the phone to stop playing, and you have to manually start play on the phone again.
Some of the buttons on the radio will control the phone to get to different tracks, but it is not great. There is a nice spot above the glove box you can attach it with velcro and not have cables going everywhere or rip the dash apart to hide it.
Post by Outrun » Fri Sep 09, 2022 1:03 pm
I haven't checked but this company does OEM integration stuff.
https://www.usaspec.com/
audipwr1
Post by audipwr1 » Fri Sep 09, 2022 10:46 pm
Thanks guys I’ll hunt these down
oddomatik
Badge Number: 98-0542
Post by oddomatik » Sat Sep 10, 2022 5:05 pm
The NSX community is pretty crazy about those Grom units. No personal experience though.
Post by coolhandluke » Mon Sep 12, 2022 1:01 pm
PrinceAli has run setups previously leveraging the disc changer input. I'll ping him, it might have been Grom.
audipwr1
Post by audipwr1 » Fri Sep 16, 2022 10:28 pm
Thank you
Dot_tom
Post by Dot_tom » Sat Dec 24, 2022 2:18 pm
I was looking into trying this company. Has anyone used the ghost box?
Looks like it plugs into factory unit and has a good power boost at 50w 4 channel.
https://www.jordandistributors.com/prod ... st-box-2-0
shuttlepilot
Post by shuttlepilot » Tue Dec 27, 2022 6:11 pm
Their website is pretty vague, but their install video shows it to be a radio eliminator, not a intercept of control and signal. https://youtu.be/7HZdKOVis9E?t=40
There is nowhere to plug your radio in if you want to keep that. They only note to reinstall a unpowered radio to keep that oem look.
g3teg97
Badge Number: 98-0379
Post by g3teg97 » Thu Dec 29, 2022 6:30 pm
Dot_tom wrote: Sat Dec 24, 2022 2:18 pm I was looking into trying this company. Has anyone used the ghost box?
I have one installed in my R. I wanted to remove the Sony aftermarket radio and put the stock one back in. Problem is it will not light up the factory radio AND use the Ghost Box. It's either or. My mechanic is making a harness so that the radio will light up and I could use AM/FM radio or CDs if I want or switch to the Bluetooth via the Ghostbox.
