2023 - where to source axles
audipwr1
Post by audipwr1 » Tue Feb 21, 2023 8:02 pm
Turns out last shop that worked on my car prior to me owning it gets an F.
Going to need new hubs (oem and can get at dealer) and the passenger axle outer spline isn’t in great shape - someone torque gunned it in and didn’t have the splines well engaged
Is there a place to either just get the entire outer assembly - if not best source for axles? I see OEM as being NLA
Re: 2023 - where to source axles
Post by coolhandluke » Wed Feb 22, 2023 10:28 am
Do you track the car? If yes, I would opt for the Raxles "VIR Spec" replacement axles. I also previously ran Drive Shaft Shop Stage 1 axles over a decade, ~40x track weekends, but I can't say if they model are still available. If not tracking, there are aftermarket new-units or one can find used OEM axles and rebuild, which tend to be higher quality.
audipwr1
Post by audipwr1 » Wed Feb 22, 2023 1:18 pm
Only track for this will (hopefully) be annual itr expo
Post by coolhandluke » Wed Feb 22, 2023 5:15 pm
Okay thank you, tracking removes the option for third-party axles from an autoparts store.
If you are open to spending a bit more for a hassle-free experience that should last years, I would consider Raxles or Drive Shaft Shop.
audipwr1
Post by audipwr1 » Thu Feb 23, 2023 12:26 pm
On waitlist at Raxles
Guy seems legit about 700 for the set he says
Post by Stin1 » Thu Feb 23, 2023 1:57 pm
If you can find oem axles, Acura and Honda had the boots/ grease & clamps as a kit. The Acura kit actually only had metal snips with no clamps vs. the em1…. They are the same axles only one has the abs ring which the itr will have.
audipwr1
Post by audipwr1 » Fri Feb 24, 2023 9:41 am
Its the outer spline that is damaged.
Driveshaft - 4-6 weeks
Raxle - hopefully parts in next week unsure on timing i guess
Post by aw614 » Fri Feb 24, 2023 11:31 am
audipwr1 wrote: Thu Feb 23, 2023 12:26 pm On waitlist at Raxles
Raxles are legit,
Thats with core or without core?
I have two raxles on mine, but one is about 10 years old and starting to leak a bit, with a slight cracks showing on mine. I have other raxle cores to send back though, but with the cost of my trans rebuild, I am holding off for now...
g3teg97
Badge Number: 98-0379
Post by g3teg97 » Fri Feb 24, 2023 2:19 pm
I heard about these guys on an Integra FB group: https://www.detroitaxle.com/
No experience with them though.
audipwr1
Post by audipwr1 » Sat Feb 25, 2023 8:50 am
Their website is a bit confusing
The passenger side axle for a dc2 fits all
Trims right? Their site says that isn’t so
But if I order a passenger axle that fits an LS it will also fit an ITR right??
