Oem radio / usb input
audipwr1
Re: Oem radio / usb input
Post by audipwr1 » Mon Feb 27, 2023 3:46 pm
Grom installed
Super easy to install
Integration also seamless - plugged my Iphone in, loaded up Amazon music - and out it came from radio.
One black usb cable exits tunnel near passenger seat for plug in / rest is all OEM
No noise / clean sound.
Would recommend
Post by Stin1 » Mon Feb 27, 2023 5:22 pm
audipwr1 wrote: Mon Feb 27, 2023 3:46 pm Grom installed
Would recommend
Why didn’t you post the install? Does it plug into the alpine round adapter for the six disc CD player?
audipwr1
Post by audipwr1 » Mon Feb 27, 2023 7:44 pm
Haha 2 little kids that mean I have zero time to do the work let alone make posts about it!
Yes literally plug it into cd changer port on oem radio and turn on radio
Hit cd button
Works first try
Pretty easy remove stuff to get at back of radio
2 sided tape unit behind dash
Run cord underneath center console
Post by Outrun » Mon Feb 27, 2023 7:47 pm
Will it charge your phone too? Have you tried a flash drive loaded with mp3s?
audipwr1
Post by audipwr1 » Tue Feb 28, 2023 11:36 am
It shows as the phone charging, but I would expect SUPER low amps so its likely still draining while plugged in
I only have iphone to use it with - though it says in the directions USB stick formatted in a few different ways will work too
JDMJNKY
Badge Number: 0874
Post by JDMJNKY » Sun Apr 09, 2023 9:48 am
bookmarking. thank you gents.
