Post by DC231 » Tue Jun 06, 2023 6:24 pm
Dave7CDMTYPER wrote: Mon Jun 05, 2023 1:36 pm Quick update. I got my block back from Golden Eagle. Still waiting on the head from 4Piston.
I have yet to start assembly, mainly b/c I'm nervous about what to do about bearings. I recently met a guy who builds race cars. I might "hire" him to help me out with this step so I do it correctly.
Don't over think it.
If you're using the original main bolts and there was no machine work done to the main bore then just go with a standard sized set of your choosing.
I usually get a standard set and an extra clearance set which is .001 more clearance. Then I can manipulate the clearances to be where I want with each main bore. You want more clearance on the center main bore to allow crankshaft flex.
Get some green plastigage not red. Do a dry install and set the plastigage on each crank journal don't move the crank and torque the mains down then pull it apart and see where each falls and you can change the bearings around to tighten or loosen it if you need to. You can mix and match the bearing halves to get a .0005 split if you only need a small adjustment.
Let us know what you decide to do :thumbup: :thumbup:
Post by Dave7CDMTYPER » Tue Jun 06, 2023 9:16 pm
DC231 wrote: Tue Jun 06, 2023 6:24 pm Don't over think it.
Thank you sir. That race car builder is gonna come by and help me with the bearing measuring process and to start assembly.
JDMJNKY
Badge Number: 0874
Post by JDMJNKY » Wed Jun 07, 2023 7:05 pm
Sweet updates! Log with pics if you can!
Post by Dave7CDMTYPER » Wed Jun 07, 2023 10:49 pm
JDMJNKY wrote: Wed Jun 07, 2023 7:05 pm Sweet updates! Log with pics if you can!
Sure I'll post some pics. Just getting over the nervousness haha.
JDMJNKY
Badge Number: 0874
Post by JDMJNKY » Fri Jun 09, 2023 9:06 pm
I just slapped the rotating assembly in a clients B18C1...nothing to be nervous about. You got this man!
Post by Dave7CDMTYPER » Sun Jul 09, 2023 6:10 pm
JDMJNKY wrote: Fri Jun 09, 2023 9:06 pm I just slapped the rotating assembly in a clients B18C1...nothing to be nervous about. You got this man!
Thank you sir!
Post by Dave7CDMTYPER » Sun Jul 09, 2023 6:14 pm
Update! Starting to make progress again. I met a guy who builds race cars, he's going to help me assemble the engine. But I'll do it with him and learn as we go. He came over yesterday and we measured the crank journals. They are all in spec, so standard sized bearings will work. We figured out the color codes etc. I want to go with new oem bearings if possible, I'll see what Honda has in stock. Once I get those and maybe a few more new bolts etc for bottom end then we'll assemble! After bottom end is assembled then we'll do the cyl head. I still need to post pics of the cyl head after it came back from 4 Piston.
Post by coolhandluke » Mon Jul 10, 2023 11:14 am
Rad. Assembling an engine was always a goal of mine. I bet this will be a fun learning opportunity.
JDMJNKY
Badge Number: 0874
Post by JDMJNKY » Mon Jul 10, 2023 2:07 pm
Lets go!! I know it'll happen...it's your first build, so my only cheat offering is to put the oil squirters in the moment you're done finalizing the main clearances. KIU!!!
Post by Dave7CDMTYPER » Tue Jul 11, 2023 5:26 pm
coolhandluke wrote: Mon Jul 10, 2023 11:14 am Rad. Assembling an engine was always a goal of mine. I bet this will be a fun learning opportunity.
Yes sir! Same with me, always wanted to do it. I'm excited.
JDMJNKY wrote: Mon Jul 10, 2023 2:07 pm Lets go!! I know it'll happen...it's your first build, so my only cheat offering is to put the oil squirters in the moment you're done finalizing the main clearances. KIU!!!
Oil squirters for sure! Gotta remember those. :thumbup:
