WTB: Upper & Lower OE Suspension Bolts
Post by coolhandluke » Sat Sep 02, 2023 12:57 pm
I'm searching for used/spare OE suspension bolts. I'm hoping many were like me, and swapped out their lower suspension bolts during refresh or rebuilds (After a few moves, these old parts are spread across many states-none of which I reside, and likely gone.) I'm now back to a shell post-theft, I intend to run through what the thieves left when they slapped on a four-leg.
Mission: Make shell safe and reliable to tow
Current list as of May 2024:
Front Suspension Needs:
-Front fork pinch bolt, PN 90120-SB0-003
-Front shock absorber bolt, PN 90175-SH3-005
-Lower balljoint castle nut, PN 90363-SF1-000
-Upper control arm ball joint castle nut, PN 51464-S04-013
-Outer tie rod castle nut, 94030-10080
Stretch ask:
-Front forks (potentially)
oddomatik
Badge Number: 98-0542
Re: WTB: Upper & Lower OE Suspension Bolts
Post by oddomatik » Sat Sep 02, 2023 1:23 pm
EDITED - feel free to delete
Post by DC231 » Sat Sep 02, 2023 3:38 pm
coolhandluke wrote: Sat Sep 02, 2023 12:57 pm I'm searching for used/spare OE suspension bolts. I'm hoping many were like me, and swapped out their lower suspension bolts during refresh or rebuilds (After a few moves, these old parts are spread across many states-none of which I reside, and likely gone.) I'm now back to a shell post-theft, I intend to run through what the thieves left when they slapped on a four-leg.
Specific parts:
*Front and Rear upper strut hat nuts to attach tow of shock assemblies to chassis
*Front fork bolts, upper and lower, to attach front shocks to lower front control ams
*Front upper control arm bolts/nuts (memory is fuzzy)
*Front tie rod nuts
*Rear upper control arm bolts, even used upper control arms if available
*Rear tow adjustment bolts for rear trailing arm
*Rear trailing arm (bushing) bolts to chassis
Far-stretched ask:
*Fuel pump cover nuts/bolts
I should have everything you need. I'm currently in the process of swapping over parts from a crashed car to a new donor and both cars have complete suspension. The crashed car will eventually be posted up for parts once I know exactly what I need for the donor car.
Post by coolhandluke » Tue Sep 05, 2023 1:47 pm
DC231 wrote: Sat Sep 02, 2023 3:38 pm
Specific parts:
*Front tie rod nuts
Far-stretched ask:
:heart: :trophy:
Post by coolhandluke » Sun May 26, 2024 9:11 pm
Updated list:
-Front forks, yes- discontinued, but any DC/EG will work
ph8ed4life
Post by ph8ed4life » Tue May 28, 2024 3:57 pm
I’ll check my garage, I’m thinking I may have a lot of what you’re needing here.
Post by coolhandluke » Wed May 29, 2024 9:09 pm
ph8ed4life wrote: Tue May 28, 2024 3:57 pm I’ll check my garage, I’m thinking I may have a lot of what you’re needing here.
You are a huge help, thank you! :thumbup:
Post by DC231 » Sat Jun 08, 2024 3:41 pm
Stretch ask:
Sorry I haven't gotten you those items yet Ryan. I do have every item you are looking for though including steering wheel, booster and all the hardware. Man I've been super busy this year so I'm running behind on some things. Shoot me a text and let's chat about what parts you may or may not still need and I'll prioritize it for you sir...
