I havnt decided yet. I got my itr running, aligned, and tuned, and i aint gonna lie, i kinda like the stock interior with a stock k20 in it. Its very "driveable" right now.
But to answer your question: I am going custom, a friend that does metal work will be designing/fabricating the cage to meet class rules + fit my seats. I have Spoon buckets and PCI static mount rails, so they wont slide, with willans harnesses.
I wanna enjoy it a bit before it becomes fully dedicated.
Roll Bar / Roll Cage Options?
Re: Roll Bar / Roll Cage Options?
Are Spoon seats certified?
- white rocket
Not at all from what I remember.
They are not FIA certified. Do they need to be? I know for harnesses they need to be, but I was unaware of the buckets needing them. At least the HFF rules do not specify FIA buckets only. Maybe more of a reason to stick with oem seats + belts or sell the spoon stuff.
The certification may or may not be required for your intended series. Most W2W or TA groups required certified seats, so I would check your rulebook. The certification is important since it solidifies the MFG went through the appropriate crash tests.noahf wrote: ↑Thu Jan 11, 2018 8:50 pm They are not FIA certified. Do they need to be? I know for harnesses they need to be, but I was unaware of the buckets needing them. At least the HFF rules do not specify FIA buckets only. Maybe more of a reason to stick with oem seats + belts or sell the spoon stuff.
I recommend:
-All OEM seats + seatbelts (SRS)
or
-Certified fixed back seat, harnesses, and rollbar
Mixing and can reduce safety.
Thanks luke. May be looking to get rid of my spoon setup and switch it to a jdm oem setup.
Too bad you aren’t closer my JDM recaros will be up for sale soon. I ended up ordering an Autopower setup.
