A History of 01-0193: Part 6
Pics from 2015
No fun pics from this year, just maintenance (but hey, car was in good shape, so can't complain!):
01-0193:
01-0193:
Re: A History of 01-0193: Part 6
Great thread. Awesome documentation. Beautiful car.
Much appreciated! Although I definitely enjoy keeping the car in tip-top shape, I fully appreciate I'm feeding my OCD tendencies, which is totally counter-productive to actually having fun with the car
01-0193:
01-0193:
Summary of 2016
2016 was great. I got the car out to three track weekends on the new pads and tires and the car was even awesomer than I remembered. I had a bit of an itch for some fun car stuff this year as well, so I had a few things picked up and plans as you’ll see below.
Maintenance:
Miscellaneous stuff:
Maintenance:
- After the suspension work late last year, early in 2016 I got 2 rounds of alignments, so the car was nice and OEM tight.
- My last set of RE71Rs were looking a bit ragged, so I picked up a new set for the track wheels.
- Oil change at 1/2016 w/ Amsoil 0W30 (w/ UOA)
- Another oil change at 5/2016 (after 2 track weekends)
- The Primary O2 sensor failed, so got that replaced with a Denso/OEM replacement
- Got a new valet key cut at the dealership -- the car never came with one
- Installed SPA Designs oil temperature & pressure gauges, as well as got a custom baffles & bung installed in the OEM oil pan by Devon M
- Picked up a nice set of used Volk TE37’s in bronze (16”x7”) for use as “all season” wheels (the OEM 15”s are the track wheels)
- Found a new set of amber OEM turn signals, so got some protective clear film installed and plopped those on the car.
- Got new OEM front and rear bumpers, and got them painted (along with the OEM lip on the car)
01-0193:
01-0193:
Pics from 2016
After a May event at Carolina Motorsports Park, the ol RE71Rs were basically sandpaper'd away:
Sweet new gauge setup:
Engine UOA from 1/2016:
Engine UOA from 5/2016:
01-0193:
01-0193:
Summary of 2017
2017 was a bit of a fun one. In late February, I was at VIR and on the second day of the event, I burnt a valve, (pics of the head below), so that really prompted a large overhaul of the engine lasting from the end of February up through April to get the engine running again. Unfortunately, I can’t speak to the cause of why the valve failed — might have been a combination of various things maybe the valve was adjusted on the tight side, maybe the buildup on the valve created a hotspot and coupled with the harder driving during the track event caused the failure. In any event, after getting the engine back together, I spent the rest of the year “getting it sorted”, running a break-in period for a few hundred miles, and overall getting confidence that the rebuild was solid. In addition to the cylinder head rebuild, I also had a bunch of other cosmetic items I just had on the backlog that I also performed this year.
Maintenance:
Maintenance:
- Transmission fluid change at 1/2017 using Honda MTF (w/UOA)
- Oil changes:
- * Got the cylinder head reworked and put it back on by April/May, so had a short interval oil change using conventional oil Mobil 5000.
- * After a few hundred miles as a break-in, I replaced with Amsoil 0w30 in Sept
- Troff in Raleigh, NC did the headwork — The head needed 8 new OEM exhaust valve guides, and 6 new OEM exhaust valves, and machined and seated all 16 valves, and machined head to ensure flatness (I had measured using a straight edge and the head actually was within service spec, so perhaps this wasn’t needed, however, I decided to opt for the extra machining just to go for 100%. The cylinder block was also within flatness service spec as well, though it wasn’t 100% flat within 0.002").
- I performed the head reassembly myself (this was a lot of fun — I really enjoyed this part). In reassembling the engine, I used ARP headstuds, all new OEM gaskets (headgasket, exhaust gaskets, intake manifold gasket, throttle body gasket), except for a Myhondahabit oil pan gasket, new o-rings in the cylinder head and distributor, and a new cam plug.
- While I was in there, I also swapped in new OEM spec NGK spark plugs, OEM timing belt, tensioner, tensioner spring, cam seals and crank seal. I also replaced the water pump and refilled with fresh Honda coolant.
- I purchased a new oem oil pan with DevonM-welded baffles. As a side note, I noted a small oil drip after the reassembly, and I thought it was my original oil pan (thought that maybe I tweaked it on installation), but turned out I had cracked a cam seal and that was ever so slowly dripping oil. So, in sum, I didn’t need a new oil pan, but I purchased one anyway, so this one is a lesson for “diagnose first, then replace the faulty part”.
- Replaced the power steering hoses and refilled with fresh PS fluid.
- Lots of new bolts/nuts,clips, clamps and other miscellaneous parts while I had the engine all apart.
- After the engine was back in one piece, I performed a valve adjustment and refilled with conventional oil
- I then re-checked valve clearance after running the car a few hundred miles
- Replaced valve cover (the original valve cover’s paint was starting to flake)
- Replaced armrest (swapped badge) as original’s suede was rough and red stitching was fading
- Installed freshly painted OEM bumpers and repainted OEM lip that I had got prepped up back in 2016 (including new front A badge!)
- Installed new rear tail light gaskets (higher density foam than OEM from Detroit Muscle Technologies on eBay)
- Installed new Type R stickers on driver’s side and rear tailgate (original ones were faded and had some flake on the red R)
01-0193:
01-0193:
Pics from 2017
Car goes under the knife:
Bit of coolant (probably head gasket failed too)
Head removed from engine:
Better view of top of pistons:
My work area littered with parts:
Cylinder head top-down view with cams removed (and a toe):
Underside look at the cylinder head
Better view of the failed valve:
Carbon buildup on other exhaust valves:
The grossness in the failed port and valves:
The car starting back up!!!!! (Note that this is just a video of a running motor with no check engine lights -- this isn't super exciting unless the engine has been disassembled for months, so this was pretty huge for me )
https://youtu.be/3lKFqS06lg0
Compression test results actually put down better numbers than when I bought the car:
And the boring transmission UOA:
01-0193:
01-0193:
- Badge Number: 234
Bummer about the engine but glad it's all back in working order.
y shi - who thinks '18 is gonna be great
00 ITR #234
00 Bolt EV
21 Highlander Hybrid
00 Bolt EV
Oh that data! Love it! Thanks for sharing your R's Journey!
Summary of 2018
Nothing too wild and crazy this year. A buddy of mine and I picked up a project car last year to be a track rat (a 91 EF hatch with an H22 swap), so spend a lot more time wrenching on that one than on the ol' ITR this year. Still, went to a few track days and the car was holding up well post head rebuild. I did have an "incident" with my bike rack (was in a parking garage and the clearance was *almost* enough) where I attempted to drive under a support beam on the ceiling of the garage and the seat of the bike hit the beam and popped off the car and put a few small dents in the roof and pillar area. Can't fix stupid... Luckily PDR fixed those really well, so I don't have to relive that mistake every time I see the dents .
Maintenance:
Maintenance:
- Replaced the battery with an OEM Acura unit (was running a small Deka battery for about 2 years, and it finally gave up the ghost)
- Oil change in June w/ Amsoil 0W30 (w/ UOA)
- Some PDR work to remove the dents from the bike rack.
- Bit of detailing (minor corrections for a few blemishes and light micromarring).
01-0193:
01-0193:
