wanted to buy 37820-P73-A04
turbo3.6
Post by turbo3.6 » Mon Jan 29, 2018 2:18 pm
wanted to buy usdm 00-01 type r computer.
cash ready, paypal ready, I can pick up in San Diego.
want to buy one asap.
37820-P73-A04
text me 619-957-1686
Jim
thanks in advance.
9701TypeR
Re: wanted to buy 37820-P73-A04
Post by 9701TypeR » Mon Jan 29, 2018 3:32 pm
I saw one on Craigslist LA or inland empire recently, check there.
Post by aklackner » Mon Jan 29, 2018 7:19 pm
When you find an ecu make sure you check that the sticker above the connectors (inside case) matches the sticker on the outside , the board number (farthest from the connectors) should be A3Y-B 001AC-L5002-00, and the three large digits printed on the largest chip on the board should be 111 for the p73-A04 (I'm told these digits indicate the program that's on the chip). At this age it's probably a good idea to confirm none of the capacitors are popped and no burn marks or oxidation is visible on any of the components.
When I was first on the hunt I was taken by a civic ecu that had been swapped into the case for a P73-A04. :(
If the rectangular resistors on the board edges (toward the connector) side aren't secured under the gold color holders this is a good indicator the board has been removed from the case at some point
Happy hunting.
turbo3.6
Post by turbo3.6 » Mon Jan 29, 2018 9:00 pm
thanks for all the help!
still looking....
check the ie craigslist, couldn't find~
I am new for these, so if you have a legit one, I am willing to buy right away. just don't sell me a bad one... :D
thanks again!
Jim
Post by Dave7CDMTYPER » Tue Jan 30, 2018 12:46 am
Post by Dave7CDMTYPER » Tue Jan 30, 2018 12:55 am
turbo3.6
Post by turbo3.6 » Tue Jan 30, 2018 12:37 pm
thank you guys!
hope the one on craigs still available.
I will email him today since there are no phone number !!
turbo3.6
Post by turbo3.6 » Fri Feb 09, 2018 12:21 pm
finally got one.
thanks for all help typer club.
now it's time to get immobilizer remove.
AFSpec
Post by AFSpec » Sat Jun 09, 2018 4:47 pm
Any more luck finding P73-A04’s?
California this month started a statewide smog station crackdown and thousands of people’s star smogs are becoming ref requirements now after the state cracked down on enforcement and ECU data checking.
The 01 USDM B18C5 I swapped into my civic for the last 6 years (and was BARd then) has been re flagged for another ref check for this years smog. And with out that A04 ECU my civic is going down for PNO until it can be registered.
ITR98
Post by ITR98 » Mon Jun 11, 2018 9:06 pm
I have an A04 I might get rid of.
