Spoon calipers and wheel go bye bye . Replaced with oem units . Also the cig burned itr seats get switched with my snatchback seats. They were kind of gross imo.
Ctr wheel I owned since 2003 added as well.
I removed these for the correct mats. Also a new shift knob.
Used oem transmission from hmo and new oem clutch. . I had to keep aftermarket flywheel. The itr one is discontinued and uses s superseded part that isn't lightened like the original.
The car had a weird gargle . Sort of a diesel gargle. I pulled the plug wires and found two with oil filled. Here is what I found
Housing problems
this arrived and the Box was beat as you can see. The fender survived unscathed. Had to repair this.
