Timing belt has 12,000 miles, after 9 years, can I...
carpayments4life
Post by carpayments4life » Sun May 06, 2018 10:19 pm
It was my daughter's High School car and she graduated in 2008.
I bought her a new Civic SI, for college and the PY sits, under a cover, in my garage.
I had the TB replaced, in May of 2009, when the ITR had 65,000 miles.
It's been 9 years and 12,000(ish) miles, since the TB, water pump, tensioners, pulley, etc. were changed.
I try to drive it every month and sneak a Winter run or two in, when the weather permits.
This time can I just replace the belt and not all of the other parts or can I wait a few more years?
Re: Timing belt has 12,000 miles, after 9 years, can I...
Post by Stin1 » Sun May 06, 2018 11:23 pm
I would change it. You are past the service interval by a few years. You should do the water pump and timing belt at a minimum. The seal as well at the lower end. I would do everything personally.
Post by Dave7CDMTYPER » Sun May 06, 2018 11:58 pm
So your daughter drove a type r in high school? That is very cool. :thumbup:
Post by coolhandluke » Mon May 07, 2018 12:56 pm
I change my TB, tensioner, and spring every 2-3x years as cheap insurance. It is ~$125 for all three items and a few hours of my labor. Memo, make sure to torque the tensioner bolt to spec.
MadMax
Post by MadMax » Sat May 12, 2018 8:38 am
So when I got my 01 last year it still had the original TB and WP (had been sitting a long time). Interestingly, the original belt had zero cracks in it but the water pump seal was about to let go. Do both and the tensioner.
Post by Lturner » Sat May 12, 2018 10:22 am
Ha ha nice screen name.
