oil pan baffle necessary at expo?
97cwr
Post by 97cwr » Mon May 21, 2018 11:42 am
I picked up an oil pan baffle and I'm not sure if I can get it installed before the expo. I was just wondering is it a must to have? how many don't run one? I'm in the amateur grouping, running a stockish integra type r with re71 r tires and koni/gc suspension. I've done a couple track days with just the stock oil pan, but just wondering if this track and my setup will require one?
Re: oil pan baffle necessary at expo?
Post by Lturner » Mon May 21, 2018 12:38 pm
I would recommend one. But most of us have tracked a lot without one. I don’t have one on the rhd. I just keep the oil topped off.
Post by jayhaire » Mon May 21, 2018 1:12 pm
It's nice to have, but you can get by without one if:
- keep oil level up (watch this before each session)
- not running R-comps
That was our general rule ~15 years ago. Novice group is slow enough to keep the lateral Gs down also.
Post by hootrscootr » Mon May 21, 2018 1:28 pm
I've never run 1 and never had a problem at VIR or Road America but like the others said, watch the oil level and run the good stuff.
Post by RTW DC2R » Mon May 21, 2018 2:27 pm
Youll be fine just check your oil after each session. Ive done a lot of tracking and have only lost VTEC once through a corner. It was at VIR at Expo 16 through Hog Pen but that corner has high compression grip and lateral G's. My oil was very low too :hammer:
Dominion doesnt have any high grip corners like Hog Pen so I think anyone will be fine there with a stock pan and sufficient oil level.
97cwr
Post by 97cwr » Mon May 21, 2018 6:41 pm
thank you guys. i'll do without it for the expo.
Chase_acura
Post by Chase_acura » Tue May 22, 2018 8:06 pm
install at track? lol 8-)
97cwr
Post by 97cwr » Tue May 22, 2018 10:10 pm
a few extra hands and a welder??? Lol. actually, you made me think about something. what's the craziest repair/mod done at an expo? This is my first so, maybe a vet can chime in...
Post by Lturner » Tue May 22, 2018 11:04 pm
Head swap expo 9? Or Craig replacing valves expo 14?
Post by jayhaire » Fri May 25, 2018 9:37 pm
Willard doing a final drive install at Expo 3? :o
I think we've had just about everything done at Expo over the years. 18 years...the event is legally an adult now.
