VIN Stickers
audipwr1
VIN Stickers
Post by audipwr1 » Mon Jun 25, 2018 8:44 pm
I searched high and low and couldnt find a good answer here so forgive me if repetitive.
Where do I find Vin stickers on the front bumper, rear bumper (and are there stickers on the rear quarters?)
Going to look at a car that for sure has had the front driver quarter replaced and trying to see how far the damage went.
Re: VIN Stickers
Post by Dave7CDMTYPER » Mon Jun 25, 2018 10:21 pm
What year is the ITR?
audipwr1
Re: VIN Stickers
Post by audipwr1 » Mon Jun 25, 2018 10:32 pm
It’s a 2001
Re: VIN Stickers
Post by aklackner » Mon Jun 25, 2018 10:41 pm
Assuming you mean front driver side fender damage? Quarter panel would be rear of the door for an Integra.
IIRC: vin sticker will be on fenders mount strip just under hood (not sure if all years had them). I want to say door vins are at the rear near the latch. I also want to say front bumper vins should be just under the hood but I’m less certain on that. All are generally pretty obvious. Check if underside of hood is painted, aftermarket hoods will sometimes be left a primed black and won’t have any factory stickers.
RDOT stickers indicate a factory replacement part, any thing else and YMMV.
I also recommend looking for consistency in the orange peel of the paint. As well as ridges where door jams were taped excessive (non-matching orange peel) or masking ridges in jams are indicative of poor paint jobs IMHO.
If pearl color make sure the amount of pearl matches to your needs (matching pearl and metallic is harder for aftermarket paint).
For front end damage check the radiator support as best you can to be sure there is no un-repaired damage there.
GL
Re: VIN Stickers
Post by Dave7CDMTYPER » Mon Jun 25, 2018 10:51 pm
AFAIK the front bumper VIN is under the black panel thing that you have to unscrew some screws and lift off to see sticker.
audipwr1
Re: VIN Stickers
Post by audipwr1 » Tue Jun 26, 2018 12:54 pm
Can you elaborate re the front bumper? That’s the one I want to check for extent of side damage
touringteg
Re: VIN Stickers
Post by touringteg » Tue Jun 26, 2018 1:18 pm
It is called the FRONT UPPER BUMPER STIFFENER BRACKET 71142-ST7-000. (or FUBSR for short :P ) I bought one from my dealer a while back as I have a bit of rust bubbling on mine.
https://www.amazon.com/1994-2001-Acura- ... B07259RYP3
The VIN sticker is supposed to be underneath. Open the hood and remove the 9 screws with a large Philips screw driver. I have not taken mine off to confirm yet (2001 CDM).
CW ITR 01-1233 CDM Sold
CW ITR 98-0635 CDM
CW CTR 17-01818 CDM
Re: VIN Stickers
Post by Dave7CDMTYPER » Tue Jun 26, 2018 2:00 pm
touringteg wrote: Tue Jun 26, 2018 1:18 pm It is called the FRONT UPPER BUMPER STIFFENER BRACKET 71142-ST7-000. (or FUBSR for short :P ) I bought one from my dealer a while back as I have a bit of rust bubbling on mine.
Exactly. It's pretty obvious what you need to remove once you take a look.
