stock suspension ?s
- white rocket
Re: stock suspension ?s
Yeah, it's really only the springs and top hats that are of interest. Most will just get Koni yellows anyway. Used shocks are a dice roll at best.
Good to know. I should def do something like this in the future.white rocket wrote: ↑Thu Aug 24, 2017 11:50 am Yeah, it's really only the springs and top hats that are of interest. Most will just get Koni yellows anyway. Used shocks are a dice roll at best.
- white rocket
You have the means since you have OEM JDM suspension. Get Koni yellows and swap the springs and top hats over. Maybe even replace some bushings while you are in there if they are worn. You can lower the overall ride height by about 10mm IIRC by using the lower perch on the shock. Bam! stock suspension with similar ride height, completely compliant, and with dampening adjustability. Honestly my favorite set-up on any ITR.Dave7CDMTYPER wrote: ↑Thu Aug 24, 2017 5:04 pmGood to know. I should def do something like this in the future.
Sounds good to me. So are you saying the ride height would be the same as oem, but also can be adjustable? I need it to be oem height, my garage clearance is pretty close already.white rocket wrote: ↑Thu Aug 24, 2017 5:37 pmYou have the means since you have OEM JDM suspension. Get Koni yellows and swap the springs and top hats over. Maybe even replace some bushings while you are in there if they are worn. You can lower the overall ride height by about 10mm IIRC by using the lower perch on the shock. Bam! stock suspension with similar ride height, completely compliant, and with dampening adjustability. Honestly my favorite set-up on any ITR.Dave7CDMTYPER wrote: ↑Thu Aug 24, 2017 5:04 pmGood to know. I should def do something like this in the future.
- white rocket
There are different perches where the springs can sit. Pretty sure it has a position that is the same as stock height.Dave7CDMTYPER wrote: ↑Thu Aug 24, 2017 7:49 pmSounds good to me. So are you saying the ride height would be the same as oem, but also can be adjustable? I need it to be oem height, my garage clearance is pretty close already.
Great news! I'm excited.white rocket wrote: ↑Fri Aug 25, 2017 11:21 amThere are different perches where the springs can sit. Pretty sure it has a position that is the same as stock height.Dave7CDMTYPER wrote: ↑Thu Aug 24, 2017 7:49 pmSounds good to me. So are you saying the ride height would be the same as oem, but also can be adjustable? I need it to be oem height, my garage clearance is pretty close already.
