Tire Information Thread
Re: Tire Information Thread
Post by aw614 » Sat Sep 15, 2018 9:51 pm
FIY, if anyone wants to see how a 15x8 vs 15x7 205/50/15 RE71 compare with each other
g3teg97
Badge Number: 98-0379
Post by g3teg97 » Sun Sep 23, 2018 4:44 pm
I'm confused because the specs say RE71R in 205/50 has a max wheel width of 7.5".
Post by aw614 » Sun Sep 23, 2018 7:21 pm
There has been a lot of test and data from grassroots motorsports and a few others that show the 15x8 on a 205/50 being faster even with the slight stretch look it has.
I can't really explain it well. I think the articles from GRM talk about it
g3teg97
Post by g3teg97 » Mon Sep 24, 2018 12:31 pm
Damn, didn't know about that.
Post by coolhandluke » Mon Sep 24, 2018 1:09 pm
aw614 wrote: Sun Sep 23, 2018 7:21 pm There has been a lot of test and data from grassroots motorsports and a few others that show the 15x8 on a 205/50 being faster even with the slight stretch look it has.
Hrm... I will have to research this.
Post by aw614 » Mon Sep 24, 2018 1:47 pm
Here is the most recent test from GRM
https://grassrootsmotorsports.com/artic ... -re-71r-v/
There might be more articles from previous tests, but doing some searches it seems a lot on a lot of forums, the writer of the article, Andy Hollis has mentioned it a few times
g3teg97
Post by g3teg97 » Mon Sep 24, 2018 7:28 pm
The tread width on 205/50R15 tires measures about 7.2 inches, which was a nice fit for the 15×8-inch wheels we used in the first round of testing.
That just sounds weird to me.
Bridgestone says 205 width tires are approved for 5.5 - 7.5", seems like the sidewall would be stretched and create problems. Just my $0.02 cents.
Xian
Post by Xian » Mon Sep 24, 2018 8:56 pm
Manufacturer recommendations are exactly that... their recommendations for most folks/most applications. Anything motorsports related, where performance is key, is going to be tailored to the best setup regardless of what the manufacturer specs out. In this case, it’s common for street tires (with their softer sidewalls) to be faster when slightly stretched and better supported.
Having said all this, the 71R tends to be on the stiffer end of things for street tires so a half inch isn’t likely to be a huge advantage. Any of the others will benefit even more from being stretched... I ran a 225 Rival on a 15x9. IIRC, Andy’s GRM testing showed substantial gains running the 225 on a 9” wheel vs 8” wheel. Pretty sure the 245 ended up being best on a 15x10.
PS
I highly suggest folks try it for themselves. There are absolutely some cases where the tire may not be faster on the clock but nah be quite a bit easier to drive or more consistent/predictable.
g3teg97
Post by g3teg97 » Mon Sep 24, 2018 9:15 pm
Thanks for the insight on that. Guess I was thinking it's more of a hard rule or whatever. Appreciate the feedback and it made sense.
I wanna pick your brain about suspension, but I'll post over in the suspension thread.
Post by aklackner » Mon Sep 24, 2018 10:28 pm
I’ve spent 0 time in on the track but isn’t geometry a concern? Stretching means the tread is smaller than the rim cross section (think trapezoid)? If so the anytime there’s force where the tread is pulling against the cross-section you’re only pulling on a single bead vs where the tread section is at least the width of the cross section you’ll always be pulling against the bead on both sides right?
