Post
by Stin1 » Sun Oct 14, 2018 12:43 pm
Post
by coolhandluke » Sun Oct 14, 2018 7:29 pm
What is the scoop on the BMX frame?
Post
by Stin1 » Tue Oct 16, 2018 9:08 pm
coolhandluke wrote:What is the scoop on the BMX frame?
That is another one of my hobbies. I grew up racing bmx in the 80/90s . I like 90s bmx and cars. The one on the table is an expert which I don't have all the parts for. I am almost done with its bigger brother.
![IMG_1352.JPG](./download/file.php?id=622&sid=520561a0e012ef92f2b99fdfa0b368e7)
- IMG_1352.JPG (300 KiB) Viewed 1258 times
![IMG_1353.JPG](./download/file.php?id=623&sid=520561a0e012ef92f2b99fdfa0b368e7)
- IMG_1353.JPG (383.82 KiB) Viewed 1258 times
with the help from fellow collectors I obtained a paint match and then converted to the original imron paint code
![IMG_1891.JPG](./download/file.php?id=624&sid=520561a0e012ef92f2b99fdfa0b368e7)
- IMG_1891.JPG (375.32 KiB) Viewed 1258 times
![IMG_1957.JPG](./download/file.php?id=625&sid=520561a0e012ef92f2b99fdfa0b368e7)
- IMG_1957.JPG (365.47 KiB) Viewed 1258 times
It's friends
![IMG_1976.JPG](./download/file.php?id=626&sid=520561a0e012ef92f2b99fdfa0b368e7)
- IMG_1976.JPG (464.36 KiB) Viewed 1258 times
Post
by Stin1 » Tue Oct 16, 2018 9:09 pm
Here is the before picture of that little guy. Big turn around in my opinion
![IMG_1634.JPG](./download/file.php?id=627&sid=520561a0e012ef92f2b99fdfa0b368e7)
- IMG_1634.JPG (548.96 KiB) Viewed 1258 times
Post
by Stin1 » Sun Oct 21, 2018 2:51 pm
I put my spare ecu in the car last week. The check engine light has not came back but I am expecting it to. The cabin had the fart smell again last week and afterwards I was smelling outside the car some strange unburnt vapor/ exhaust stink as it was idling in the garage. I am thinking it's a leak but I am not sure where. Pretty much the one thing my brothers shop doesn't have is a smoke machine. I don't really trust people to touch my cars who are outside my circle of friends. I will probably look and see if oreily rents one if the code comes back which I guessing will. The purge valve isn't to far from location where the hood release cable is rerouted , resulting in a small gap at the harness / grommet . Which is my guess where the sulfur stink is coming from in the cabin. If anyone has additional insight on evap code p1457 please let me know. Today I couldn't reproduce the stinch or code. Chasing this wild goose sure sucks.
touringteg
Post
by touringteg » Wed Oct 24, 2018 6:38 pm
I hate p1457. I have spent a lot including smoke test, jdm p73-003 ecu and boomslang harness (both for sale) and bought a spare p73-C04 ecu from a local og ITR owner. A heck of a rare find since it is discontinued and Acura sold about 1000 ITR in Canada. 400 00 and 01 CDM R. I sent it to @jkatman on Instagram @ffchips.com to bypass the immobilizer properly. I am 98% sure my issue is my original ecu stopped sending evap signals. I ran this ecu for a while and the p1457 code did not come back. Waiting to get the ecu back in my possession. Edit: Got my p73-C04 oem ecu back with immobilizer bypass. No more CEL. Hopefully for a very long time!
Jdm p73-003 ecu (and jumper harness of 00 01)will work great on a USDM car and no more p1457.
Just wanted to comment on the ebrake button replacement. What a pita. The hardest part is getting it back on as the button is incredibly tight to thread on. There are a lot of threads to spin on to and you have to get tension on the spring. I wrapped mine in electrical tape and used vice grips a quarter turn at a time.
CW ITR 01-1233 CDM Sold
CW ITR 98-0635 CDM
CW CTR 17-01818 CDM
Post
by Stin1 » Wed Nov 14, 2018 10:27 pm
Got something from the the U.K thanks to acklanders thread . I contacted the seller and he included the bracket in the thread. However I think his picture below is slightly different than the bracket and different orientation than the one I I received.
![IMG_2070.JPG](./download/file.php?id=660&sid=520561a0e012ef92f2b99fdfa0b368e7)
- IMG_2070.JPG (189.07 KiB) Viewed 1141 times
Here is the bracket I received. It has some interesting U.K. Patina. I will try to resolve this with a citrus rust remover. I would prefer a original finish. I will let you know how that works out. Otherwise it has to be painted.
![IMG_2248.JPG](./download/file.php?id=661&sid=520561a0e012ef92f2b99fdfa0b368e7)
- IMG_2248.JPG (422.12 KiB) Viewed 1141 times
I don't have the original usdm purge valve bracket so this a plus 1 . This is my guess how it should go. What line is in and out I can only guess. The bracket fits perfectly on the firewall.
![IMG_2249.JPG](./download/file.php?id=663&sid=520561a0e012ef92f2b99fdfa0b368e7)
- IMG_2249.JPG (364.15 KiB) Viewed 1141 times
![IMG_2247.JPG](./download/file.php?id=662&sid=520561a0e012ef92f2b99fdfa0b368e7)
- IMG_2247.JPG (380.66 KiB) Viewed 1141 times
Post
by Stin1 » Wed Nov 14, 2018 10:30 pm
Stin1 wrote:Got something from the the U.K thanks to acklanders thread . I contacted the seller and he included the bracket in the thread. However I think his picture below is slightly different than the bracket and different orientation than the one I I received.
Post
by Stin1 » Wed Nov 14, 2018 10:34 pm
![IMG_2251.JPG](./download/file.php?id=664&sid=520561a0e012ef92f2b99fdfa0b368e7)
- IMG_2251.JPG (296.75 KiB) Viewed 1140 times
Post
by aklackner » Wed Nov 14, 2018 11:12 pm
Looks the same as I have. The nipple facing forward goes to the IM.
Pm me if you need any more photos of how I have it setup.
