Eibach/ASR 25mm adjustable hollow sway bar (Civic/Integra) + Endlinks
navin
Post by navin » Thu Nov 08, 2018 10:19 am
Generic description from ASR: The ASR 1" hollow bar is the first of its kind. Featuring a hollowed out core this bar is significantly lighter than our 24mm swaybar. The 1" swaybar also keeps the same dimensions as a OEM swaybar but is even stiffer than our 24mm swaybar due to the increased diameter.
ASR Red bar: 25.4 mm (1 in) Hollow, 3 position adjustable
Measured bar rate:
P1 = 73 N/mm (418 lbs/in)
P2 = 94 N/mm (533 lbs/in)
P3 = 111 N/mm (630 lbs/in)
Red bar weight: 3.15 kg (7.0 lbs)
https://www.asrparts.com/products/swaybar-kit
This is the for the swaybar, bushings, brackets, and spherical endlinks. Located in Fairfax, VA and willing to ship. Direct bolt on for ITR's since they don't need a subframe brace.
Price is $175 OBO
navin
Re: Eibach/ASR 25mm adjustable hollow sway bar (Civic/Integra) + Endlinks
Post by navin » Thu Nov 08, 2018 6:47 pm
sold.
g3teg97
Badge Number: 98-0379
Post by g3teg97 » Fri Nov 09, 2018 7:20 pm
Damnit. I need to put this forum on a subscription to notify me or something. I'm thinking of getting a larger rsb.
Post by aw614 » Sun Nov 11, 2018 10:56 pm
g3teg97 wrote: Fri Nov 09, 2018 7:20 pm Damnit. I need to put this forum on a subscription to notify me or something. I'm thinking of getting a larger rsb.
I ended up buying it when I saw it posted on the other forum :lol: I've been wanting to try this bar for quite some time with the stock suspension.
g3teg97
Post by g3teg97 » Mon Nov 12, 2018 6:57 am
Oooh, what other forum?? Haha.
Let us know your thoughts in maybe that big suspension thread. I'm on stock suspension too and I think I need a bigger rear bar.
