Old school B series rebuild - FULL story
Aquafina
Re: Old school B series rebuild - FULL story
Post by Aquafina » Wed Jan 09, 2019 10:09 pm
Good stuff Doug.
Post by Dave7CDMTYPER » Wed Jan 09, 2019 10:56 pm
What compression would you guys do with 93 octane?
Post by aklackner » Wed Jan 09, 2019 11:15 pm
From what I’ve read, 93 is pretty safe into upper 12 to 13 over that can be done but is pushing it.
Aquafina
Post by Aquafina » Fri Jan 11, 2019 2:09 pm
Safe is a moot point if you have to pull timing to make it safe. 12.5:1 with 93 and you'll be pulling timing. If the 93 is just to get you to a track where you switch to race gas that is a different story.
JDMJNKY
Badge Number: 0874
Post by JDMJNKY » Sun Jan 13, 2019 5:35 pm
What a beauty, very nice numbers.
hungsteR
Post by hungsteR » Tue Jan 15, 2019 12:15 pm
Which model Skunk2 70mm TB did you choose to match with the Skunk2 ultrastreet IM?
98 CW ITR
00 FBP ITR - SOLD 03/2006
BabyNSX
Post by BabyNSX » Wed Jan 16, 2019 1:33 am
hungsteR wrote: Tue Jan 15, 2019 12:15 pm Which model Skunk2 70mm TB did you choose to match with the Skunk2 ultrastreet IM?
I'm using the 70mm Pro Series black TB:
https://skunk2.com/induction/throttle-b ... y-820.html
So far its working great and likely helped me pick up some top end torque/power over the 68mm TB I was using before.
3pedalJohn
Post by 3pedalJohn » Fri Jan 18, 2019 11:19 am
Awesome Build, love seeing people still building the B series.
I built a 84mm B18C1/ 10.5:1 with ITR cams, made 206WHP and 143WTQ (dynojet #'s) with a CAT'd 2.5" Hytech exhaust. The extra displacement is awesome :D
Have you considered using the RDX injectors?
Post by Dave7CDMTYPER » Fri Jan 18, 2019 12:39 pm
This is the kind of b series build I want to do. Must be such an awesome engine to drive.
Post by coolhandluke » Fri Jan 18, 2019 6:08 pm
3pedalJohn wrote: Fri Jan 18, 2019 11:19 am Have you considered using the RDX injectors?
The most difficult aspect of RDX injectors is finding a fuel rail that properly aligns and seats the injectors. Many on the market are simply adapted for RDK, leading to improperly spray angle (less power) or leaks.
Users browsing this forum: Google [Bot] and 3 guests
