Post
by aw614 » Sat Mar 02, 2019 1:52 pm
Just to update this thread, being paranoid about the temps for the track in Florida, I decided to swap out my denso oem replacement with Koyo V083146. With the stock fans and JDM 4-1 header and heat shield clear without any issue
Pic:
DSC_0093 by
Andrew Wong, on Flickr
Post
by coolhandluke » Sat Mar 02, 2019 3:14 pm
aw614 wrote: ↑Sat Mar 02, 2019 1:52 pm
Excellent information, thank you for sharing.
Post
by RTW DC2R » Sat Mar 02, 2019 3:42 pm
My koyo worked fine with stock fans, but had to tweak the shroud to work with my Toda rep header. Switched to Spal fans and have plenty of clearance.
Post
by aklackner » Sat Mar 02, 2019 10:16 pm
Koyo with OEM shroud looked good but when driving over time dug into AC compressor line fitting.
![Image](//uploads.tapatalk-cdn.com/20190303/3f4d0caaf1f2162cbeec947337ba91dd.jpg)
- Site Admin
- Badge Number: 97 #00151
Post
by jayhaire » Sat Mar 02, 2019 11:34 pm
aklackner wrote: ↑Sat Mar 02, 2019 10:16 pm
I had a similar thing happen to my AC line while using a Koyo and OEM fans. It was a rough discovery (hot summer afternoon, stuck in traffic on way to GingerMan) when the AC failed to work.
I replaced the line and the fans with slim Spal fans. No issues since then.
Post
by aw614 » Sun Mar 03, 2019 3:14 pm
Guess is time to pull the dremel to trim that part of the shroud. Mine is also touching that part of the ac line
