Integra dc/eg parts
All non-ITR/CTR Cars and Parts can be posted for sale here.
Integra dc/eg parts
Post by DC231 » Thu Apr 11, 2019 11:27 am
Picture links added in post 3
92-93 integra empty casing--1 bolt thread broken off on bottom side but never leaked after damage occurred.----$210 shipped
94-01 integra bellhousing/front trans case half--SOLD
94-01 GSR crankshaft--no spun bearings very good condition/perfect keyway--SOLD
94-01 GSR block--VIN still present/81mm but needs to be bored over/all caps girdle and main bolts included--SOLD
B18c oil pick up tube--$30 shipped
Moroso baffled oil pan--SOLD
36mm axles not sure if these are OEM but the boots are not dry rotted at all--SOLD
integra/crv obd2 non vtec valve cover-2 available--$50 each shipped
suspension techniques front and rear sway bars--rear has never been mounted and is missing the hardware--front has everything--part#50157 and 51145--$200 shipped
94-01 GSR spoiler OEM--SOLD
94-01 GSR strut tower bar OEM--powder coated black a while back ago--has some scuffs/scratches--SOLD
obd2 alternator--rebuilt less than 10k miles ago locally--powder coated black(casing) and silver(pulley and rear cover)--$100 shipped
94-01 integra manual pedal assembly--clutch/brake/gas pedals--$90 shipped
94-01 integra shift linkage--bushings/shift lever included--SOLD
AEM Series 2 obd2b part# 30-6050--brand new--Rywire obd1-obd2b jumper harness included--SOLD
Marren 750cc fuel injectors obd1--pigtails included--SOLD
00-01 Integra GS/LS engine harness manual trans--uncut/unmodified--SOLD
92 civic si engine harness--modified with obd2 injector clips--very clean looks unmodified and original--$100 shipped
Re: Integra dc/eg parts
Post by coolhandluke » Fri Apr 12, 2019 1:41 pm
DC231 wrote: Thu Apr 11, 2019 11:27 am for pics and inquiries text...
Pictures only help sell and are required, per forum rules. The community can help if there are questions while posting pictures. There is a write up on posting pictures via mobile app:
viewtopic.php?f=8&t=136
Post by DC231 » Mon Apr 29, 2019 7:37 am
DC231 wrote: Thu Apr 11, 2019 11:27 am 92-93 integra empty casing--1 bolt thread broken off on bottom side but never leaked after damage occurred.----$200 shipped---https://www.ebay.com/itm/264266636316
94-01 GSR crankshaft--no spun bearings very good condition/perfect keyway--$200 shipped---https://www.ebay.com/itm/264266615591
Moroso baffled oil pan $100 shipped---https://www.ebay.com/itm/264293962612
36mm axles not sure if these are OEM but the boots are not dry rotted at all--$120 shipped---https://www.ebay.com/itm/264294014617
integra/crv obd2 non vtec valve cover-2 available--$50 each shipped---https://www.ebay.com/itm/264294010232
suspension techniques front and rear sway bars--rear has never been mounted and is missing the hardware--front has everything--part#50157 and 51145--$200 shipped---https://www.ebay.com/itm/264294007605
94-01 GSR spoiler OEM--$80 shipped---https://www.ebay.com/itm/264294005550
94-01 GSR strut tower bar OEM--powder coated black a while back ago--has some scuffs/scratches--$50 shipped---https://www.ebay.com/itm/264293997240
obd2 alternator--rebuilt less than 10k miles ago locally--powder coated black(casing) and silver(pulley and rear cover)--$100 shipped---https://www.ebay.com/itm/264294000265
94-01 integra manual pedal assembly--clutch/brake/gas pedals--$90 shipped---https://www.ebay.com/itm/264293992575
AEM Series 2 obd2b part# 30-6050--brand new--Rywire obd1-obd2b jumper harness included--$850 shipped---https://www.ebay.com/itm/264107917622
Marren 750cc fuel injectors obd1--pigtails included--$90 shipped---https://www.ebay.com/itm/264218238810
00-01 Integra GS/LS engine harness manual trans--uncut/unmodified--$100 shipped---https://www.ebay.com/itm/264175462980
for pics and inquiries text 904-414-0451
Post by DC231 » Mon Apr 29, 2019 7:38 am
picture links added
Post by aw614 » Sun May 05, 2019 7:30 pm
For the 00-01 engine harness are all the clips on it? And I take it if I am running obd1, I will need to add the tach wire to it still?
Post by DC231 » Mon May 06, 2019 12:53 pm
aw614 wrote: Sun May 05, 2019 7:30 pm For the 00-01 engine harness are all the clips on it? And I take it if I am running obd1, I will need to add the tach wire to it still?
Yes all of the retainer clips are there and all of the electrical clips are there and intact. This engine harness has not been modified in any way. Yes I believe that the tach wire will need to be added.
