Wtf is this ? Booming system?
This is much better than the little skinny whatever that was . Thanks for part number Mark .
- Sp00nFedFilms
I need to get my canister in so we can chase these codes together lol.
Good answer on the plug for the EDM valve. That’s why mine has it probably, because the harness is from the 01.
I found a old for sale post of the car that was probably 10-15 years old and that code was an issue. I am sure no one has tried to resolve it. The code usually stays out long enough that it passed emissions was the comment I believe.
Still waiting for the new ground wire, I tried cleaning my old one and some of the crud on it would need a deep clean, but the black wire looks good. I think a few of us must have bought it b/c it finally shipped out after ordering it last week
I ended up using an Acura RL EVAP I found here, sadly it looks different from an ITR and the ACURA TL one you bought, but it mounts up to the firewall area and on my non-R DC4 Vin car, it looks OEM when mounted. I haven't noticed any issues with it, but I haven't tested out an obd2 ECU to make sure. But no funny smells or anything.
https://www.ebay.com/itm/39W024-EVAP-PU ... 2749.l2649
What's the part number for that black ground wire?
ITR Expo 8 & 16 attendee
1998 #729
IG: NOCSUCOW
1998 #729
IG: NOCSUCOW
It sucks some have to play a guessing game what will work. Honda should help clean our air and produce the valves along with the evap lines again. The rl you posted appears to have the obd2b plug as opposed to the round 98 plug.aw614 wrote: ↑Fri Jul 19, 2019 7:35 am Still waiting for the new ground wire, I tried cleaning my old one and some of the crud on it would need a deep clean, but the black wire looks good. I think a few of us must have bought it b/c it finally shipped out after ordering it last week
I cry for type r parts too often. FedEx has killed two type r mufflers and now this! This one is a real heart breaker. Viewers warning. Graphic images. I am traumatized.
