I got that valve. It goes by the gas tank under the car. I never knew about either of these valves. AlldatA says to check valves but doesn't specify where they are.
This is what I need to find and change . It's supposed to be on the left side at the bottom of the gas tank .
Will be installing mine in the next few days, though for an 00 so will be a bit different. I can share picks if it’s helpful
Absolutely! Kevin recommended new lines off that valve near the gas tank. I am going to check availability tomorrow. I am also going to try on the rubber hose that goes between the other valve and the canister. Haven't had any luck on any of the evap lines at the canister or the purge. They have been discontinued since I bought the car.
According to Acura the associated hoses on the rear valve are discontinued. Same by the canister except one little bulk hose that isn't pre molded .
I have changed the run channel on the driver side. I don't know but this thing is there.
Not a clue on this side? Anyone Know which side the blue tape is supposed to be? I am assuming the top.
Here we go again my friends. More non cool no fun part here . I buy a lot of stuff from Honda and Acura. Some strange stuff the average consumer doesn't buy, just like some of you do. I always take notice if I get a different decal, or something. This one is a weird one. The dealer gets their shipments in bulk. This one came from Tennessee. Number # 940 has some roots in Tennessee. Just one box was shipped. Anyway, here's the picture.
I have the tape and a new subseal.
What is # 9 for?
The em1 has no tape and the other portion that isn't on the integra I recall it on the run channel possibly?
