When the article was first released I looked at a few items that are discontinued with the integra . On the s2k catalog I didn’t find anything discontinued in the U.S . Take for granted I don’t own one to look for any specific parts.Little_Nolan wrote: ↑Tue Jun 16, 2020 5:07 pmNever know on the ITR. RIght now Honda does not have a competitor in their sales line up for the S2K... But now there are things which are similar to the ITR (CTR). While we all know its a major difference between the two, Honda might think otherwise. IDK.Dave7CDMTYPER wrote: ↑Tue Jun 16, 2020 4:12 pm If Honda has an S2K part program, surely they'll come around to doing the same for ITR?
Those spoon parts are inspiring! Hope they also do the same for dc2.
Also, the S2k program is specific to Japan right now.
The Replacement Parts Thread
Re: The Replacement Parts Thread
Not to add to the frenzy, but I placed an order today and they responded with this:
Part No. Description Order Qty. Status ETA* to Dealership
77715-ST7-Z01ZA Panel, FR. Ashtray *TCARBON*
[Integra | 2000 | 3 Door TYPE-R | KA 5MT] 0 Discontinued -
Discontinued parts are removed from the order.
51312-SD4-020 Rubber, Stabilizer End
[Integra | 2000 | 3 Door TYPE-R | KA 5MT] 0 Backorder No ETA*
Back ordered without an available date. This part is removed from the order.
51320-ST7-003 Link Assy., FR. Stabilizer
51392-ST7-013 Bush, FR. Arm (LOWER)
[Integra | 2000 | 3 Door TYPE-R | KA 5MT] 2 On Order 06/29/2020
On order to Acura's warehouse with an estimated arrival date.
51810-SH3-004 Bush, Shock Absorber (YAMASHITA)
[Integra | 2000 | 3 Door TYPE-R | KA 5MT] 2 In Stock Ready for shipment
52390-SR0-A00 Arm, R. RR. (UPPER)
[Integra | 2000 | 3 Door TYPE-R | KA 5MT] 1 In Stock Ready for shipment
52400-SR3-000 Arm, L. RR. (UPPER)
52341-SR3-000 Arm, RR. Compensator
52314-ST7-Z00 Bush, Stabilizer Linkage
52315-ST7-Z01 Bush, RR. Stabilizer
52316-ST7-Z00 Bush, Stabilizer End
51306-ST7-Z01 Bush, Stabilizer Holder
It appears that it is only the front and rear stabilizer bushings and end links that are Backordered with No ETA and everything else is still available. I'll keep checking and help with the update.
I will be really disappointed if sway bushings also go discontinued.00DC2R wrote: ↑Mon Jun 22, 2020 7:51 pm Not to add to the frenzy, but I placed an order today and they responded with this....
...It appears that it is only the front and rear stabilizer bushings and end links that are Backordered with No ETA and everything else is still available. I'll keep checking and help with the update.
I'm overdue to help document in here but I have already started testing OE replacement parts. I hope to catch up over the upcoming July 4th break.
The following I got in the last week through Amayama:
They might be close to discontinued but Amayama got them.
PS I want to have Amayamas babies.
Amayama is sweet. I got all the oem parts for the jdm 4.7 FD several years ago.Klasse wrote: ↑Thu Jul 09, 2020 8:18 pm The following I got in the last week through Amayama:
I will consider upgrading my Rear LCA's to these pieces:
https://www.mpcmotorsport.com/product-p ... ntrol-arms
These won't be an option for anyone wanting rubber bushings. I would also consider sending these direct to Kingpin Machine as I would prefer sphericals for the track since my car is primarily driven to and from the track now.
Any alternatives to the left and right steering knuckles? Even Rock Auto doesn't have any equivalent parts.
https://www.acuraexpressparts.com/oem-p ... 1TUjMtTjAw
Looks like you have to find used (have blasted and Powdercoat) or maybe check if hmo has a set?
You can make JDM work but I think you’d have to run the larger “36mm” axels then. This is what I have on 01-386. You can use RSX-S axels (swapped side to side) with a spacer Karcepts makes (kwhb1). Then you have the option of CRV or RSX-S hubs depending if you want an ITR (282mm) or RSX-S (300mm) rotor respectively.
I'm on another parts hoarding bender, and I'm looking at transmission parts. No major issues currently with my gearbox but one day no doubt.
When people are rebuilding these is it generally the 5 bearings and 3 synchro sets that are replaced? Is the 5/R synchro commonly done? Looking at OEM while it's available but the cost is high. Synchrotech just as good/better? Anything else in there often replaced? I realise it's difficult without having it apart.
