ITR Fuel Tank
ddwelch
Re: ITR Fuel Tank
Post by ddwelch » Wed Mar 14, 2018 12:45 pm
I do not have any info to your specific questions. However, I will note that I bought a tank off ebay and sort of had a tough time getting the fuel pump mounted as the studs were sort of off. Also the fuel float/sensor hole was way to small to fit the oem unit through and I just ended up capping it off. My car is mostly just for track use, so I keep the tank full for every event.
Re: ITR Fuel Tank
Post by aklackner » Wed Mar 21, 2018 9:18 pm
Got the Spectra tank today.
Packaging was not terrible but not sure it would survive well if a carrier was careless with it.
Was surprised that it came with a set of gaskets, mounting ring (for rear center vents), and new fasteners.
As expected not completely 1:1 but looks like it will work pretty well and is reasonable quality.
At this point I’m sure by see any issues with fitment.
I staged the old OEM pump sender and vents to ensure they all fit properly.
I didn’t weight any of the tanks. From feel I’d guess they’re pretty close but if I get a chance I’ll drop them on a scale and see If there’s any major difference in weight.
Photos:
Re: ITR Fuel Tank
Post by Dc2-ProductionS » Thu Mar 22, 2018 7:24 am
So it looks like from pictures that it is also the same internally? Looks to have a "similar" bowl size and the angled baffles also.
Thoughts after inspecting the two? I need to order a new tank myself. I don't think it's worth dealing with a tank that has been sitting for more than 10 years, Ive been watching this thread as it popped up at the perfect time! LOL Thanks!
Re: ITR Fuel Tank
Post by aklackner » Thu Mar 22, 2018 1:49 pm
For me, the Spectra tank should fit the bill. Getting an OEM replacement tank that doesn't have some form of oxidation from sitting around (likely empty) isn't realistic.
I'm a little curious about the basket design differences though minimal. There might be a few situations (steeper grade with low fuel level) where the OEM design could ensure better access to fuel.
OEM
Spectra Premium Replacement
