Page 2 of 2
Re: LSD Talk - Which MTF for Clutch Style LSD?
Posted: Fri Jul 10, 2020 10:52 am
hondarcb wrote: Thu Jul 09, 2020 8:05 pm For what it’s worth, myself and 3-4 other racers are using Motul Gear 300 75W90 with the OS Giken. Most have been for a few years. Myself just starting this year with the switch to the Giken. All B series cars.
Added, thank you for contributing this information. :thumbup:
Dave7CDMTYPER wrote: Thu Jul 09, 2020 8:36 pm Would this be the right thread to also list recommendations for oem LSD fluids?
I vote yes, we could expand into Clutch + Helical types. I just need to change the title. :beer:
Posted: Fri Jul 10, 2020 11:50 am
by PatHidden
I believe Spoon and Kaaz are the same. Spoon just rebrands Kaaz if I remember correctly.
When I was running a Kaaz in my integra I would use GearX oil. Always felt notchy when cold, but once up to temp on track it was fine.
http://www.specialprojectsms.com/produc ... -gear-oil/
Posted: Fri Jul 10, 2020 11:54 am
PatHidden wrote: Fri Jul 10, 2020 11:50 am I believe Spoon and Kaaz are the same. Spoon just rebrands Kaaz if I remember correctly.
I wasn't aware, thank you for sharing. I'll update shortly. :thumbup:
I added, Section 2 - Helical LSD MTF Fluids Recs to the OP. Let's keep the content building going!
Re: LSD Talk - Which MTF for Clutch Style & Helical LSD?
Posted: Wed Aug 05, 2020 9:36 pm
I've had a new ITR trans sitting in storage for a while. It looks like my buddy is gonna help me install it soon on my gs-r. I might consider the fluids recommended in the OP, below:
"OEM ITR:
Recommended MTF's:
-Amsoil
-GM Synchromesh FM
-Torco MTF
-Torco RTF *Can be mixed with Torco MTF 50/50"
But I wonder if I should use a certain fluid for break-in?
Simply because I like to have fun with cars, it'd be cool if royal purple would work...
Posted: Thu Aug 06, 2020 3:48 pm
If the transmission is a new build or BNIB OEM, I would plan to cycle oil after the first full tank for break-in. You can use the fluid mentioned or straight (no detergent/etc) cheap dyno oil in 10w30. I did this for my original MFactory transmission build in my thread and it's still going strong.
Clutch LSD's are a different story.
Posted: Thu Aug 06, 2020 5:33 pm
coolhandluke wrote: Thu Aug 06, 2020 3:48 pm If the transmission is a new build or BNIB OEM, I would plan to cycle oil after the first full tank for break-in. You can use the fluid mentioned or straight (no detergent/etc) cheap dyno oil in 10w30. I did this for my original MFactory transmission build in my thread and it's still going strong.
Good to know! :thumbup:
