OEM reman power steering rack from acura?
Re: OEM reman power steering rack from acura?
Post by Stin1 » Mon Jul 16, 2018 3:18 pm
Could be none or both. Depends on the extent of your leak. In dc2 productions pic above you see the gear box . They will leak there . They will also leak at the dust bellows on the ends . All of it ends up on the subframe and the parts below as well as behind it. You can see it dripping from the bushing but it is probably cleaned up by now .
