Page 3 of 5
Re: Old school B series rebuild - FULL story
Posted: Wed Jan 09, 2019 10:09 pm
by Aquafina
Good stuff Doug.
Posted: Wed Jan 09, 2019 10:56 pm
What compression would you guys do with 93 octane?
Posted: Wed Jan 09, 2019 11:15 pm
From what I’ve read, 93 is pretty safe into upper 12 to 13 over that can be done but is pushing it.
Posted: Fri Jan 11, 2019 2:09 pm
by Aquafina
Safe is a moot point if you have to pull timing to make it safe. 12.5:1 with 93 and you'll be pulling timing. If the 93 is just to get you to a track where you switch to race gas that is a different story.
Posted: Sun Jan 13, 2019 5:35 pm
by JDMJNKY
What a beauty, very nice numbers.
Posted: Tue Jan 15, 2019 12:15 pm
by hungsteR
Which model Skunk2 70mm TB did you choose to match with the Skunk2 ultrastreet IM?
Posted: Wed Jan 16, 2019 1:33 am
by BabyNSX
hungsteR wrote: ↑Tue Jan 15, 2019 12:15 pm
I'm using the 70mm Pro Series black TB:
https://skunk2.com/induction/throttle-b ... y-820.html
So far its working great and likely helped me pick up some top end torque/power over the 68mm TB I was using before.
Posted: Fri Jan 18, 2019 11:19 am
by 3pedalJohn
Awesome Build, love seeing people still building the B series.
I built a 84mm B18C1/ 10.5:1 with ITR cams, made 206WHP and 143WTQ (dynojet #'s) with a CAT'd 2.5" Hytech exhaust. The extra displacement is awesome
Have you considered using the RDX injectors?
Posted: Fri Jan 18, 2019 12:39 pm
This is the kind of b series build I want to do. Must be such an awesome engine to drive.
Posted: Fri Jan 18, 2019 6:08 pm
3pedalJohn wrote: ↑Fri Jan 18, 2019 11:19 am
The most difficult aspect of RDX injectors is finding a fuel rail that properly aligns and seats the injectors. Many on the market are simply adapted for RDK, leading to improperly spray angle (less power) or leaks.
