Page 22 of 84
Posted: Sat Jul 13, 2019 4:44 pm
by DC231
aklackner wrote: Sat Jul 13, 2019 1:22 pm All is good, just short on time to get back into the build.
It’s sort of been family event and house project season lately. The shift in focus has helped while the fun funds recover from paint and custom hard lines.
The good news is I should be wrapping up with the house projects for now in the next couple weeks, I have $900 in Honda seals and hardware on the way, and should get the rest of the parts I need to layout the custom lines for the WMI setup today.
glad to hear things are on track :thumbup: :thumbup:
im curious as well to know what you decided on for seals and hardware
i was going to tell you not to forget to order these tailgate hinge seals 68217-SK7-000 x2 but they are now discontinued.. i would just cut my own seals with an innertube. you should also be sure to get the rear beam seals 71544-SR2-000 x4 or you could cut seals for this as well since you will need to do some others anyways. these are often and easily overlooked and will cause leaks into the interior so i wanted to point them out to you.
Posted: Sat Jul 13, 2019 10:54 pm
Since there was some curiosity, the order had some of the door and hatch seals, and a lot of hardware for hardlines. Just an order to get things started, there will be a lot more to order. A couple items were discontinued from the initial order.
Part Number Part Name Price Quantity Total
17766-S01-A00 Stay F, Fuel Pipe $5.74 1 $5.74
91599-S01-A00 Insulator Rubber, Fuel Pipe $2.81 1 $2.81
93405-06016-04 Bolt-Washer (6X16) $1.03 5 $5.15
91597-SR3-003 Clamp C, Fuel Pipe $1.19 1 $1.19
91598-S04-A01 Clamp D, Fuel Pipe $7.20 2 $14.40
17763-S01-A00 Stay C, Fuel Pipe $6.06 1 $6.06
91597-S04-A01 Clamp C, Fuel Pipe $5.53 2 $11.06
17764-S01-A00 Stay D, Fuel Pipe $6.06 1 $6.06
91594-S01-A00 Insulator Rubber, Fuel Pipe (B) $3.64 1 $3.64
90361-S7S-003 Nut, Paint Cutting (6MM) $1.70 3 $5.10
91596-S01-A01 Clamp B, Fuel Pipe $7.20 1 $7.20
17762-S01-A00 Stay B, Fuel Pipe $6.06 1 $6.06
91595-S01-A01 Clamp A, Fuel Pipe $7.20 1 $7.20
90301-SV7-000 Nut, Paint Cutting (6MM) $3.06 1 $3.06
16923-S84-A00 Collar, Distance $0.73 1 $0.73
17322-S84-A00 Rubber, Canister Mounting $2.87 1 $2.87
17322-S04-000 Rubber, Canister Mounting $2.79 1 $2.79
17358-ST7-L01 Bracket, Canister $22.50 1 $22.50
91561-SP0-G01 Clip, Headlight Washer Hose $3.44 1 $3.44
17361-ST7-A00 Bracket, Dust Filter $17.86 1 $17.86
17742-S04-A01 Pipe, Canister Drain Joint $13.93 1 $13.93
93405-08016-08 Bolt-Washer (8X16) $1.14 1 $1.14
46380-SH3-000 Grommet A, Brake Pipe $3.50 2 $7.00
93403-08020-08 Bolt-Washer (8X20) $1.14 1 $1.14
93403-06012-08 Bolt-Washer (6X12) $0.94 1 $0.94
46395-SM4-951 Clip, Brake Pipe $5.81 1 $5.81
46391-SR3-922 Clip B, Brake Pipe $6.56 1 $6.56
95801-06045-08 Bolt, Flange (6X45) $1.22 1 $1.22
46393-SM4-951 Clip C $4.22 1 $4.22
46391-SR3-J00 Clamp, Brake Pipe $7.34 2 $14.68
93402-06012-08 Bolt-Washer (6X12) $0.89 5 $4.45
93402-08020-08 Bolt-Washer (8X20) $1.07 1 $1.07
46392-SR3-000 Clip, Brake Pipe $9.45 2 $18.90
71142-ST7-000 Stiffener, Front Bumper (Upper) $47.59 1 $47.59
90120-SB0-003 Bolt, Shock Absorber Lock (10X42) $1.24 2 $2.48
72410-ST7-003 Molding Assembly, R Front Door $91.26 1 $91.26
72450-ST7-003 Molding Assembly, L Front Door $91.26 1 $91.26
72321-ST7-A00 Seal R, Front Door Ho $27.28 1 $27.28
72361-ST7-305 Seal, L Front $27.85 1 $27.85
72310-ST7-023 Weatherstrip, R Door $77.31 1 $77.31
72350-ST7-023 Weatherstrip, L Door $77.31 1 $77.31
75760-SB2-003 Pin, Door Checker $5.50 2 $11.00
72325-ST7-023 Sub-Seal, R Front Door $45.50 1 $45.50
72365-ST7-023 Sub-Seal, L Front Door $46.46 1 $46.46
74440-ST7-000 Weatherstrip, Tailgate $96.87 1 $96.87
90307-S03-000 Nut, Spoiler Cap (6MM) $3.38 4 $13.52
Subtotal: $871.67
Estimated Standard Shipping: $28.38
Total: $900.05
Posted: Sat Jul 13, 2019 11:06 pm
Dang, everything was available too ? I see you said things were nla. What were they?
Posted: Sat Jul 13, 2019 11:22 pm
aklackner wrote: Sat Jul 13, 2019 10:54 pm Since there was some curiosity, the order had some of the door and hatch seals, and a lot of hardware for hardlines. Just an order to get things started, there will be a lot more to order. A couple items were discontinued from the initial order.
Subtotal: $871.67
Total: $900.05
I would love to see the pile when it arrives. I recognize some of the stuff on the list from my purchases. The hard line stuff not so much, so I can still pretend like I haven't spent anything. I keep telling that to myself at least. I got acklander, dc2productions , and insideous proving it.
Posted: Sun Jul 14, 2019 12:39 am
Stin1 wrote:Dang, everything was available too ? I see you said things were nla. What were they?
No inner door seals and some charcoal canister items weren’t available any more:
17358-ST7-L01, 17361-ST7-A00, 17742-S04-A01, 46391-SR3-922, 72321-ST7-A00, 72325-ST7-023.
Posted: Sun Jul 14, 2019 12:52 am
This guy has the seals on the door.
https://honda-tech.com/forums/sale-10/f ... st51938550
Posted: Sun Jul 14, 2019 9:41 am
by DC231
Subtotal: $871.67
Total: $900.05
very nice!! it looks like you went all out on securing your new hard lines :mrgreen: :thumbup:
Posted: Sun Jul 14, 2019 11:45 pm
Next order placed (fuel tank parts):
Part Description Subtotal
Part No.: 90674-SD5-003
Strap, Harness
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 2.90
Part No.: 17727-ST7-A01
Tube, Vent Return
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 22.29
Part No.: 17721-ST7-A01
Tube, Signal
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 16.74
Part No.: 17710-ST7-A01
Tube, Vent
Part No.: 17360-ST7-A00
Bracket, One-Way Valve
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 6.35
Part No.: 17521-SR3-000
Band Assy., R. Fuel Tank Mounting
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 15.84
Part No.: 17522-SR3-000
Band Assy., L. Fuel Tank Mounting
Part No.: 17525-SM4-000
Bolt-Washer (10X35)
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 5.78
Part No.: 94001-08000-0S
Nut, Hex. (8MM)
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 2.72
Part No.: 94101-08800
Washer, Plain (8MM)
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 2.08
Part No.: 95002-02104
Clip, Tube (B10)
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 4.16
Part No.: 94109-12000
Washer, Drain Plug (12MM)
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 0.58
Part No.: 93901-25220
Screw, Tapping (5X12)
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 2.82
Part No.: 93893-05008-08
Screw-Washer (5X8)
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 1.40
Part No.: 93405-06016-08
Bolt-Washer (6X16)
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 2.88
Part No.: 92800-12000
Bolt, Drain Plug (12MM)
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 2.00
Part No.: 91601-SH3-013
Grommet, Screw (5MM) (Black)
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 14.82
Part No.: 91594-SR3-911
Clamp, Purge Hose
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 4.89
Part No.: 91406-SL4-931
Clamp, Fuel Hose (D10.5)
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 5.88
Part No.: 91393-SV4-000
O-Ring (No.2)
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 6.01
Part No.: 90890-SV4-000
Screw-Washer (5X16)
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 2.94
Part No.: 90700-SB0-003
Clip, Air Bleed Tube
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 10.02
Part No.: 90657-SH3-013
Clip, Valve Cover (Two-Way)
Part No.: 90657-SA5-003
Clip, Side Apron Molding
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 2.64
Part No.: 90624-SB0-003
Clip, Wire Harness
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 2.73
Part No.: 90301-SE0-J00
Nut, Flange (6MM)
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 14.70
Part No.: 90150-S04-003
Bolt, Ground (6X16)
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 2.10
Part No.: 90102-S2A-000
Bolt-Washer (5X12)
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 2.92
Part No.: 90101-S84-000
Bolt-Washer (5X10)
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 9.84
Part No.: 17711-ST0-003
Retainer (Yellow) (Tokai)
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 13.68
Part No.: 17704-SR3-930
Hose, Fuel Pipe Return
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 4.43
Part No.: 17662-S04-003
Gasket, Fuel Filler (With Clip)
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 5.87
Part No.: 17652-T0A-003
CLIP, FILLER TUBE
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 3.63
Part No.: 17652-SA5-000
Clip, Filler Tube
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 5.73
Part No.: 17574-SV1-L01
Gasket, Base
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 12.30
Part No.: 17551-S84-A01
Gasket
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 28.69
Part No.: 17376-S01-A01
Valve, One-Way
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 19.20
Part No.: 17357-S02-L01
Joint, Three Way
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 4.26
Part No.: 17012-S01-A01
Valve Set, Solenoid
[Integra | 2001 | 3 Door TYPE-R | KA 5MT] 102.23
Part No.: 91392-S02-000
O-Ring,No.1
Posted: Mon Jul 15, 2019 12:11 pm
Stin1 wrote: Sun Jul 14, 2019 12:52 am This guy has the seals on the door.
We'll see if it actually comes but 72361-ST7-305 (L inner door seal) didn't show as discontinued it's only the right side.
I don't think I really care enough since I typically pull these (plastic door sheets) any way to pay $99 just for a right side and a spare left. If I feel like adding a seal in on the passenger side, I'll just cut my own from some poly sheeting. ;)
Posted: Mon Jul 15, 2019 3:27 pm
aklackner wrote: Mon Jul 15, 2019 12:11 pm
I totally understand. They're all torn on my other cars and I never cared .
