Restoring #97-00012
Re: Restoring #97-00012
I just replaced mine using the part numbers off an oem parts site/dealer direct. The new bolts I put on the ABS bracket were definitely not the same as what I took out.
The ones that came for the bottom I used for the side since it had the large washers and used the smaller ones on the bottom as you did.
What I would like to have done was find a local place to do the zinc plating but there isn't one.
ITR Expo 8 & 16 attendee
1998 #729
IG: NOCSUCOW
1998 #729
IG: NOCSUCOW
Shoulda left that ABS stuff out
This is what the dealer provides, I can't say if they are the same as the original in terms of shape and size.
- Sp00nFedFilms
Restoring #97-00012
Looking good in here! Will I see you Sunday at Bridgewater?
Yes stin in correct with the bolts. I have the part numbers for the correct hardware in my thread. But like Stin received, I ordered all 3, 2 of which came silver and one semi yellow zinc.
- Dc2-ProductionS
- Badge Number: 97-00012
So since the BNIB harness I was going to buy sold the day before I went to purchase, I need to clean up one of the OBD2a harness I have. Years of dirt and grime had the harness looking tired, so I peeled all of the electrical tape off where it was covering any wires and cleaned up all the plugs. Still going to do a final cleaning on each plug once I get some better cleaning tools, but she is all taped back up and clean again. Should look pretty spiffy once it's on the engine and back in the caR!
I also started with the firewall harnesses cleaning them up, re-taping and checking each connection. I think once I get them all cleaned up I'm going to dab them all with some dielectric grease so everything is nice nice.
That must have been such a pain in the ass. Looks good
- Sp00nFedFilms
Harness looks great Dan.
What are you doing with the other OBD2a ITR harness? I’m in need.
- Dc2-ProductionS
Thank you sir! I'm keeping the others I have. I already sold one and regretted it as soon as I left the post office. LOLSp00nFedFilms wrote: ↑Fri Aug 02, 2019 10:27 amHarness looks great Dan. What are you doing with the other OBD2a ITR harness? I’m in need.
Thanks m8
It wasn't as bad as I thought tbh. Plus this is def a visibly rewarding task so once I got going, I was in the zone!
What did you use to clean everything on that harness? That is a beautiful sight . Where was the new harness for sale?Dc2-ProductionS wrote: ↑Fri Aug 02, 2019 8:04 am So since the BNIB harness I was going to buy sold the day before I went to purchase, I need to clean up one of the OBD2a harness I have. Years of dirt and grime had the harness looking tired, so I peeled all of the electrical tape off where it was covering any wires and cleaned up all the plugs. Still going to do a final cleaning on each plug once I get some better cleaning tools, but she is all taped back up and clean again. Should look pretty spiffy once it's on the engine and back in the caR!
I also started with the firewall harnesses cleaning them up, re-taping and checking each connection. I think once I get them all cleaned up I'm going to dab them all with some dielectric grease so everything is nice nice.![]()
- Dc2-ProductionS
Thanks! I took a good 10 mins and just looked at it myself when I was all done. LOL... I sprayed brake cleaner on a rag and wiped down the outsides of the plugs and connections. Then used a soft bristle brush to clean the outsides of the plugs. I still need to go back and do a "final" cleaning and then a touch of dielectric grease before install but was enough to re-tape everything else for now.
I peeled all the old tape off, gave a cleaning to what was underneath with some simple green spray and a rag, and then retaped nice nice.
The BNIB harness was for sale from a individual parts dealer on Instagram. Was posted for over a month, and the day I go to send payment he tells me he just sold it the night prior. I was so upset.
