98-1059 is here to stay
- Sp00nFedFilms
- Sp00nFedFilms
Re: 98-1059 is here to stay
Such a huge box for such a little piece. Sometimes Honda’s really over does it. Other times we see discontinued parts come in damage due to lack of packaging. Very inconsistent.
None the less, I’m glad it came. The now discontinued door seal.
- Sp00nFedFilms
This box looks like it could’ve been meant for a long block!aw614 wrote:That box looks like its meant for an oil pan
- Sp00nFedFilms
Decided I’m going to wash the car this weekend and install the OEM wheel locks. When I had the center caps off to balance the wheels I remembered something that was bothering me for a while, and I fixed it. Insert OCD here:
Can you spot it? If you can, the wheel lock will get the same treatment this weekend.
Yep I see it. The bottom of the "A" is pointing toward the valve stem.
- Sp00nFedFilms
Dave7CDMTYPER wrote:Yep I see it. The bottom of the "A" is pointing toward the valve stem.
So top will point to lock nut?
- Sp00nFedFilms
Exactlyaklackner wrote:So top will point to lock nut?
- Sp00nFedFilms
Freshly painted trunk brace and new hardware. Just awaiting a new trunk lock actuator.
