coolhandluke wrote: ↑Wed Mar 25, 2020 12:55 pm What are you using to clean and protect the plastics?
Im using a watered down 409 cleaner and soft bristle brushes for most stuff. Depending what the item is, sometimes I put some watered down armor all plastic cleaner on it also. Im thinking we will do a protective type layer/cleaner in the finishing days......
Stin1 wrote: ↑Wed Mar 25, 2020 4:40 pmGood lord ! The car and updates are amazing. Great work.What did you do to clean the clear hose ? Thank you for the pictures of the 97 evap.
Thank you! The clear brown hose I think was just super hot water and then snaking a towel in and out. It was in good shape, just really dirty.
John worked on wiring last night a bit trying to sort out some of this ECU craziness. I removed the rear panels to start getting all the wiring, belts, and plugs in order.
Can anyone confirm the rear hatch has wiring that connects (2 plugs) in the rear passenger side trunk area?
I then did a bunch of cleaning on some old pieces of plastic that some would call iconic to the Integra.... The smile this puts on our faces here in the garage is pretty big....
Previously I mentioned we may have had to remove the dashboard. This was because we forgot to put the windshield wiper motor plug through its port before we mounted the brake booster. **DISCLAIMER** It doesnt fit.... LOL. John stayed late after I checked out and got it wired in. I don't think he removed the dash, looked like he removed the booster from underneath and got it in. Woot woot.
I started a WTB thread in the classifieds and was previous looking for a throttle body. Well I sourced one and when I checked in the garage this morning, I found this!!
God damn does that look good!! I got a new intake arm from IRUNOEM and I have a full intake and resonator... Buttttt I also have an original CT icebox.
I want to do the CT for just a little bit of noise, but I think for resto purposes I have to use the OEM.....
He also got the rear water pipe mounted, as well as the thermostat housing. Some more things to button up on the firewall still so this stuff is really just mocked up for now. But progress is progress!!
Like an IDIOT i threw out the rubber door frame trim that is disco'd.
#10 in the image above... I scoured my entire attic and didnt find them. I was NOT a happy camper... BUT! A good friend Josh who has a few R's and boxes of parts found me a set!! I was super excited to get the text back of a video of him showing them and agreeing to part ways with them.
More and more to come, stay tuned!!
