Page 30 of 37
Re: 98-1059 is here to stay
Posted: Mon Aug 26, 2019 5:44 am
by Sp00nFedFilms
aklackner wrote:Do you also have the sort of shaped in between piece, that’s bows between the rubber pictured and the rubber on the solenoid?
I don’t. Thought this was it...
Posted: Mon Aug 26, 2019 7:42 am
by NOCSUCOW
Sp00nFedFilms wrote: ↑Sun Aug 25, 2019 11:43 pm
aklackner wrote:Beautiful, we should find some one to make a run.
Probably not a bad idea if someone knows a machinist. I’m happy it came with the rubber stay, that’s extinct as well.
That rubber piece is discontinued now? Good thing I ordered mine a month and some change ago.
Posted: Mon Aug 26, 2019 4:24 pm
by Sp00nFedFilms
Posted: Mon Aug 26, 2019 5:35 pm
Mark and I discussed this. He has the proper bracket. He is missing # 5 in the diagram, the stay . This is what I believe acklander was referring to earlier. Nla
- IMG_4059.jpg (108.37 KiB) Viewed 886 times
I also noticed his U.K.?? Bracket was angled different than mine.
- IMG_4062.jpg (338.04 KiB) Viewed 886 times
Posted: Mon Aug 26, 2019 5:38 pm
I set up my U.K. Bracket as ack said nipple forward to the manifold. Marks bracket has the stay solenoid horizontal vs vertical.
Posted: Mon Aug 26, 2019 5:42 pm
- IMG_4069.jpg (210.56 KiB) Viewed 886 times
- IMG_4070.jpg (157.36 KiB) Viewed 886 times
My U.K. Stay appears to be identical to the stay I received on my purchase of the bracket and solenoid for the u.s model.
Posted: Mon Aug 26, 2019 7:21 pm
by Sp00nFedFilms
Yup. Exactly right bud. Hopefully someone comes through with the stay for sale.
Posted: Tue Aug 27, 2019 6:59 pm
by Sp00nFedFilms
The car used to pull a bit to the right on the highway. Very bothersome when you’re used to a 2019 RDX daily driver. Time to fix that.
Good to go!
Felt good about the car so I decided to wash her. This time I pulled out all the stops. Even though the plan is for an exterior restoration this winter, I’ll be performing a light paint correction this holiday weekend.
For those who care to see the ITR day from IG...
https://youtu.be/zNUGSq9Ru_c
Posted: Thu Aug 29, 2019 1:55 pm
by Sp00nFedFilms
Just got some good news (I hope)
Received an email reply today from a month old email stating there’s a 98 ITR engine harness available for purchase. Problem is, it’s from a CDM Integra Type R.
Does anyone know if this will be plug and play in my 98 USDM?
Posted: Thu Aug 29, 2019 3:14 pm
by 9701TypeR
Sp00nFedFilms wrote:Just got some good news (I hope)
Your purge solenoid won’t plug in and if you are running a obd2b distributor from a 00-01 that also will not work.
